Can anyone explain what's happened to my hard drive and what I should do with it? MiniTool Partition Wizard shows Disk 3 looks like this:
I can still read and probably write to the real partition of 2791.49 GB. Acronis True Image Home 2014 says it successfully wrote a backup to the drive last week. I didn't create the other partitions.
I discovered the mystery when I installed a larger SSD to replace my C drive on disk 1. Acronis' clone drive feature was checking the state of all drives and it threw up a few dozen "retry ignore cancel" boxes saying "Failed to read from sector __ of hard disk 3." Check Disk says nothing is wrong. Partition Wizard's surface scan found nothing wrong.
After telling Acronis to ignore those sectors it allowed me to start cloning but then the program stopped doing anything. I disconnected Disk 3, tried the clone again, and it seemed to work. I disconnected the old disk 1 and booted from its replacement. About a minute after reaching the desktop, the mouse cursor still moved but everything else was "not responding". I disconnected disk 3, Windows booted fine, I used the computer for hours, turned it off, re-connected disk 3, it booted fine and Windows has been working for two days with the files on disk 3 read-able. Although it's working now, I'm not comfortable with the situation and just leaving it alone. Please help and advise.
