Hey everyone, this is my first post. Been lurking for a longtime and it seemed like a good place to post a question like this.
I'm building a 2U server (with a custom chassis - using 3D printed parts and a 2U rack mount shelf) for my homelab and while deliberating power supply options just decided to get a (used) regular ATX PSU - obviously the fan will be blocked because it will be against the top of the chassis. I figured I'd just cut holes in the side of the sides of the PSU case and add 80mm fans because apparently I like doing things the hard way... I originally purchased a Corsair "Shift" PSU (with connections on the side), because it seemed like it would be best to blow straight through the PSU case, in one end and out the other. The ebay seller ended up sending me a regular RM850x - I couldn't exchange it for the Shift model because they didn't have one, so I didn't bother returning it.
Point is, I've got the thing open and now I'm deliberating on fan placement. As pictured, the PSU has clear plastic insulation running along the sides of the board. Pretty sure I'd need to cut this to get good flow. So I have a few questions I was wondering if anyone here could provide their opinions on. Firstly, is this plastic entirely necessary? Seems like it obviously makes the thing safer, it should make it harder for an arc to reach the case - but I've seen PSU's without this insulation. It seems obvious that I need to cut it, but I guess rather than cut it all down, the question is where should I cut it?
This seems to come down to two factors: which components are most likely to arc, and which components need the most cooling.
-I was originally going to put two 80mm fans on the left side of the PSU (first picture) since that would allow intake from outside of the server chassis. But in terms of components that might arc, my rudimentary knowledge tells me those big ass caps are likely candidates, but I could be mistaken.
-I could put one fan in the top left position and only cut back the clear insulation up to the capacitors -this should provide good air flow to the MOSFETS with heatsinks near the middle. This seems like a low risk option because the part I'd be exposing to the case by removing insulation is the PWM board (which I think controls the switching circuits, not the fan). I could pair this with another fan on the rear exhaust vent (second photo), but from what I know axial fans are better at blowing than sucking, despite these particular fans being labelled as "optimized for static pressure", so I'm not sure about the exhaust fan option.
-I could also have an intake fan on the other side (drawing from within the chassis), where I'd assume a safe position would be bottom right due to it mostly being occupied by the 120v connection and also being relatively open to air flow - the top right position is kinda blocked by the board that the original fan plugs into (however I assume that is a safer component to un-insulate as well). This fan formation might even help create a swirling effect inside the case that might help cool all the components (last photo).
I only bought two fans, but I'm still open to just putting two on each side - and maybe even a fifth fan on the back exhaust. I feel like all that might be overkill, but it might provide enough air flow that I might not need to cut back any insulation - just the air forced over the insulation might be enough at that point.
So many options! Which do you think is best based on the relevant factors? I'm leaning toward the swirl configuration plus an exhaust fan... combining photo two and three.
Jeeze this post really turned out a lot more wordy than I anticipated. I appreciate any and all of you who take the time to read it!
