Blue screen problems 0xa00001
agus18
I'm getting problems with blue screens in windows 8.1 like 0xa00001 (more often) or kernel_data_inpage_error (only one time), and when it restarts it say :"Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key" and i cant do anything only turn of the pc and then on and goes well. The blue screens are no more than 10 in about 2 months and the most of time it happens when im watching a video
my pc specs are:
AMD FX 6300 3.5GHZ
RAM 8GB GSKILL
AMD RADEON R7 260X oc
MOTHER ASUS M5A99X EVO2.0
1TB WESTERN DIGITAL
550W SENTEY
Thanks a lot for your help!
I would look for a BIOS update for your actual graphics card. The bugcheck is not called by windows but by the graphics driver when It detects a problem.
(power issue, memory corruption in the GPU, overheating) It only seems to happen on over clocked AMD graphics card. You might also want to make sure
that you are not overclocking the PCI bus in the ASUS BIOS. (overclocked PCI bus and overclocked GPU can cause issues)
