Bluetooth Connection
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
When I am trying to connect my device with my PC i get the
following messages.
Error creating "bluetooth Serial Port" connection with
device.
If i try a quick connection I get-
bluetooth serial port connection failed could not connect
to remote device
Any ideas?...
Broadlee
it would be really helpfull if you let us know what bluetooth devices youre
trying to use - they differ in the way the s/w works.
But from your post it sounds like there's a problem with either the drivers
for ther bluetooth adapter, or the s/w ur using to setup the connection. Try
reinstalling/updating both
hope this helps
> following messages.
> device.
> to remote device
> Any ideas?...
> Broadlee
I would suggest removing the BlueTooth device and add it again. This
should set up all of its COM ports and services all over again.
Nathan McNulty
> hope this helps
>>following messages.
>>device.
>>to remote device
>>Any ideas?...
>>Broadlee
