Bluetooth, Low Latency, Noise Cancelling Headphones?
dobe12
18
Hi:
I use my headphones to watch TV. I can't seem to find any good quality over the ear headphones that have:
1. Bluetooth
2. Active Noise Cancelling
3. Low Latency
I've used Bluetooth noise cancelling phones but they have that latency issue that drives me crazy. I'm willing to spend a couple of hundred dollars or more.
Thanks
Ok So just back in time I wanted a TV headphone and I was about to buy a transmitter one but then came through Bose Sound link 2 and read some review on it moreover saw it some top tv headphones list and bought it straight away without any second thoughts.
Pros:
They are extremely light
They are open backed headphones
very light weight and comfortable
The connectivity range is by far less but if you watch tv from a distance of less than 10m then you are not going to face any issue.
Cheers:)
Below is the source of the information and from where I got to know about it using as a TV headphone.
source - http://www.gadgetsdeck.com/2017/02/wireless-headphones-for-tv.html
Pros:
Cheers:)
