Boot problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
Last Saturday I posted a message abouf the problem I have been experiencing
when I try to boot Windows XP.
The problem is Windows XP stops working after I select the Profile on the
Welcome Screen.
I can boot it in the Safe Mode, but after I have done all steps suggested in
the received responses, such as, select last good known configuration, select
a known past date when Windows was working under System Recovery, Uninstall
and reinstall the Video Card drivers - I installed a GeForce 256MB Graphic
Card 1 week before the problem starts.
One of Microsoft documents is run Windows XP CD and choose Repair then
disable the agp440 drive, because if the problem is some kind of video card
driver compatibility, it can be sorted out through this action
I also managed to boot it after I had disabled Services under msconfig menu,
so I suspect the problem stands somewhere there.
I appreciate any help in this matter
There is another important detail, my graphic card is based on the chipset
nVidia, maybe it can be useful to help you all to understand the problem.
> Welcome Screen.
Well disable the services one by one then.
http://www.uscricket.com
"Andrew Pontes" <AndrewPontes@discussions.microsoft.com> wrote in message news:E5C24491-0D9F-4C0A-B2AF-371DB116EFD6@microsoft.com...
> Welcome Screen.
