G
Guest
Guest
Archived from groups: comp.sys.hp.hardware (More info?)
my one month old pavilion zd8080 laptop started with no obvious reason
to have boot problems. after pressing the power button, all the LEDs
would light up and nothing else would happen except the hard disk
activity light which would remain on. The HP Invent screen does not
even show. I have to press the power button for a few seconds to force
shutdown. I do this for several times before successfully booting up.
Also, while working in Windows, the system would display a blue screen
with white text and starts to dump the physical memory to disk. The
system would then try to restart somtimes successfully sometimes not. I
also had a few times a white screen without the computer freezing
(connecting an external monitor would work just fine). Ended it up
turning the hardware acceleration completely off in a desperate try to
limit problems.
HP support said that this is a hardware problem and i have to send the
pc in for service (which i will have to do eventually).
Has anyone had a similar problem with this model or any suggestions to
overcome this problem till i am able to send the computer for service.
Thx.
limit problems.
Thx.
