Boot Problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
ok so i installed linux ubuntu just to try it out. and at first i was able to
boot xp from the dual boot menu but then suddenly it would get a third of the
way through the booth screen and restart so i booted with xp boot disks and
deleted the partition that linux was on and windows would almost boot but at
the autochk screren it says "autochck missing - skipping AUTOCHECK and then
it restarts and continues this over and over again in a cycle
Hi,
Autochk.exe is normally in the \Windows\system32 folder, but I'm guessing
that you didn't have a choice to redirect the search. Sounds like you need
to run fixmbr from the WinXP CD by loading the Recovery Console.
HOW TO: Install and Use the Recovery Console in Windows XP [Q307654]
http://support.microsoft.com/?kbid=307654
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Ritalin" <Ritalin@discussions.microsoft.com> wrote in message
news:3ECAB98C-735C-4B48-954E-57AF3E79658C@microsoft.com...
> to
> the
> and
> at
> then
