Question Brand new pc build won’t turn on !!! Please help
Dec 5, 2022
hello i just finish building my 3rd pc this is my first micro build. Im runnin into a issue we’re the pc lights up (ram and gpu and mother board) but I get absolutely nothing on the screen I checked allll my connections, reinstalled my ram , basically rebuilt the whole pc over again, did the “q flash” with everything unplugged still nada …. PLEASE HELP ME
AMD Ryzen 7 5700X
GIGABYTE X570SI AORUS PRO AX
PNY 16GB (2 x 8GB) RAM DDR4 3600
PNY GeForce RTX 3070 LHR
Cooler Master MasterBox NR200P
Cool master 750w
SAMSUNG 980 PRO 1tb
NZXT Kraken X63
Cool master 750w
Coolermaster is the brand of the PSU while 750W is the advertised wattage for the unit. Can you please state the model for the unit? Are any parts in your build recycled or purchased used?
Can you walk us through how you took advantage of the Q-Flash Plus button on the board?
Cool master 750w
I installed the bios for the mother board onto a usb just had the cpu and the mother board cables connected with not cpu or gpu connected. And I plugged in the usb and held the button until I saw flashing.
It started to flash , it’s flashed slower then it stopped so I thought it was done, connected everything back together and and still nothing.
The power supply is “used” so is the case that’s it got them off Amazon.
the psu should be
750 SFX Gold 750W Full-Modular 80 Plus Gold SFX Power Supply
