[SOLVED] Brand new PSU fan stuck at 100% speed!?
zac9500
Hi all,
I've just picked up a BeQuiet! Dark Power Pro 11 1000w Platinum PSU. I've built my PC, it's all working fine, except I noticed one fan was always really loud.
I set all fans to 500rpm in the BIOS and it was still there, checked again and it's my PSU fan. It's running at 100% speed constantly even when the PC is idle and I can't work out any way to slow it down or stop it.
Does anyone know if this indicates a broken unit or whether I can change this? It's very loud and annoying for a "silent" system!
Thanks
The fan isn't auto in that model from what I remember so it sounds like you have a defective unit or someone replaced the fan with a higher speed one.
Ahh crap. Likely a defective unit I think as the unit was brand new, and the fan inside is the factory Silent Wings 3... 🙁 Thanks
Hi all,
Thanks
How much RGB do you have in your system? Fans? Lighting strips? etc.?
