Archived from groups: alt.comp.hardware,comp.sys.ibm.pc.hardware.storage (More info?)
On WD ATA 160 Gb drive. Specifically the 12v pin broke off at the base. WD
won't support it at all, or even provide parts. Just want to get info off
without spending big $ on data recovery. Is there such a thing as a
replacement wire that would fit in the hole (pin was hollow) and fit the
hole and the connector so that the disk would be powered? Would I be able to
pull the connector off an old hard drive? Sorry if this sounds stupid,
completely new to this, but I assume I can't be the first person this has
happened to.
happened to.
