[SOLVED] Broken CPU cooler pins on my stock intel cooler.
Matevz_1
13
So today I accidentaly broke three of my coolers pins. I somehow put the cooler back on the CPU but it's a little loose. The temperatures are around +5C than normal. Is this an ok temporary solution? I will new ones as soon as I can but it may take a while because of coronavirus.
The cpu will not allow you to harm it, it'll throttle or shutdown if temps become unmanageable, just to save itself. So as long as temps are within the cpu parameters for working temps, you are fine. Just continue to monitor the temps and try not to put the cpu to extreme usage.
