Brother MFC 4800 drum reset problem
Dan
2,208
Archived from groups: comp.periphs.printers (More info?)
Hi
I just replaced a drum unit (DR250) in a Brother MFC 4800. Everything
went OK until I happened to look at the display. It still told me that I
needed to replace the drum! Can anyone help me with how to reset the
drum counter in this unit? Unfortunately the "Starter Sheet" must have
gone out with the trash since I can not find it.
Any help would be appreciated.
Dan
dan wrote:
> Hi
> Dan
Look here for everything you ever wanted to know about your machine.
http://solutions.brother.com/mfc4800/download/index.html
Yaz2040
yaz2040@att.net wrote:
> dan wrote:
>>Hi
>>Dan
> Yaz2040
I checked out the site - unfortunately I found nothing on reseting the
drum counter. Thanks anyway.
dan
> > dan wrote:
> >>Hi
> >>Dan
> > Yaz2040
> dan
Perhaps this will help?
http://tonerrefillsplus.com/printerreset.html
Search for 4800 on the page.
Yaz2040
>>>dan wrote:
>>>>Hi
>>>>Dan
>>>Yaz2040
>>dan
> Yaz2040
Thanks Yaz2040
I had a look at the link and this is the info for the 4800:
Brother Cartridge Part #DR-250
OEM Stated Yield: 20,000
(Also used in the DCP-1000/MFC-4800 and MFC-6800)
New drum cartridges come with a clear "Starter Sheet" installed inside
the cartridge. Install the cartridge but keep the cover open. Press the
"CLEAR" button to show the drum status. The display will show REPLACE
DRUM? 1. YES 2. NO Press "1" on the telephone keypad. The counter is
reset! Full size copies of the sheet are available upon request.
Unfortunately the MFC-4800 does not have a "CLEAR" button and I tried
every other button combo that I could think of with out any success. I
will have to see if I can track down a service manual for this unit - it
should be in there.
dan
> >>>dan wrote:
> >>>>Hi
> >>>>Dan
> >>>Yaz2040
> >>dan
> > Yaz2040
> Thanks Yaz2040
> should be in there.
> dan
Dan:
Sorry to hear this. I was hoping that site would answer your questions.
I've exhausted my meager knowledge of these things. Good Luck.
Yaz2040
This is how I reset the drum count on my HL-5250:
open the unit--as if you were replacing the toner or drum--hold down the Go button for five or six seconds; close the unit and then print a status report.
