[SOLVED] Brother MFC9130CW Laser Printer with bad color gradation and streaking
by "print density adjustment " if you mean calibration, yes I've performed calibration several times, but it deosn't change how the prints come out. If not please let me know.
Your manual lists the consumables and maintenance intervals. It's extremely important to follow the maintenance intervals exactly as laid out or your printer will become a very expensive boat anchor in short order.
If you don't already have the manual then find it here: https://support.brother.com/g/b/manualtop.aspx?c=us&lang=en&prod=mfc9130cw_us
You'll find the drum unit replacement guide in the "Setup Guide" section at the above link.
Thanks for the info. I'm looking into it.
