BSOD after overclocking CPU. need some help
bradbrad12345
Hey,
First time making a post so if i missed anything let me know but yeah like the title says I'm in need of some help! I over clocked my CPU to 4 ghz after following a guide. After over clocking i used the intelburntest and it passed and seemed stable with temps of 80 to 83 at max load.
However at random my pc will blue screen, sometimes i can play DayZ for hours with no issues then other times it can bcod within 20 minutes. When i turn my pc back on I get the blue screen bccode: a
My Specs:
mobo: Asus P6X58D-E
processor: I7 920 CPU (d0 chip)
cpu cooler: Titan Fenrir TTC-NK85TZ
ram: DDR3 pc3 10666 gold series
gpu : sapphire r7 260x 1gb
Settings I changed in the bios:
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting......................[21.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[191]
PCIE Frequency.........................[100]
DRAM Frequency.........................[DDR3-­1531MHz]
UCLK Frequency.........................[3063M­Hz]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.22­500]
CPU PLL Voltage........................[1.80]
QPI/DRAM Core Voltage..................[1.21875]
IOH Voltage............................[1.12­]
IOH PCIE Voltage.......................[1.50]
ICH Voltage............................[1.20­]
ICH PCIE Voltage.......................[1.50]
DRAM Bus Voltage.......................[1.64]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[800mV]
CPU Clock Skew.........................[Delay 300ps]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Disa­bled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Disabled]
CPU TM Function........................[Disable­d]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[­Disabled]
Intel(r) C-STATE Tech..................[Disabled]
iateab
4
You could go up on your vcore 0.05 and that would probably solve the problem of BSOD. Unfortunately that might increase your temps to unsafe levels as you're already a little borderline. I would either decrease the overclock or go with a more effective cooling solution.
bradbrad12345
Thank you for the advice iateab, I will increase my vcore to 1.275 and see what the temps are looking like; what settings would you recommend to decrease in the bios if they are 2 high? sorry i'm a noob
edit: temps were 85-90 oc after 6 runs of intelburntest(decided to stop after 1 core hit 90)
Similar threads
