Question BSOD DRIVER_POWER_STATE_FAILURE (9f)
Slayerrcks
37
Mostly new build from back in January 4th. I randomly seem to get this BSOD. I might notice it when I do long sessions of games. Initially happened twice at the beginning of the month then happened again today. Was playing MH Wilds and using the Nvidia app to try and force DLSS 4. I stopped playing and stepped away for a little bit then came back after maybe 10 minutes to a bsod.
*edit* I've tried running scannow/sfc and it didn't come back with any issues. I had a previous 8 year old HDD connected and thought that might be the issue and removed it. The bsods stopped but now its happening again.
*edit 2* This is my first time building with a modular PSU and don't know if maybe there is a potential issue with how the cables are plugged in.
Specs:
Microsoft Windows 10 Pro Version 10.0.19045 Build 19045
MOBO ASRock X870 Pro RS
BIOS Version/Date American Megatrends International, LLC. 3.11, 11/1/2024
GPU: RTX MSI Gaming Trio 3070ti
GPU Driver: 32.0.15.7260
CPU: AMD Ryzen 7 9800X3D 8-Core Processor, 4700 Mhz, 8 Core(s), 16 Logical Processor(s)
RAM: Corsair Vengeance 32gb https://pcpartpicker.com/product/Jk...6-gb-ddr5-6000-cl30-memory-cmk32gx5m2b6000c30
Hard Drives:
C: WD_BLACK SN770 1TB
D: Samsung SSD 970 EVO Plus 1tb
F: WD_BLACK SN770 2TB
G: Seagate Barracuda 4TB Internal Hard Drive 3.5 Inch SATA 6Gb/s
CD Rom drive.
PSU: Corsair RM850e (2023) 850 W 80+ Gold
Parts from the old build are the GPU, the Samsung SSD, the HDD, and the CD Rom Drive.
Two monitors one 2560x1440 the other 1920x1080
Memory Dump Link:
https://drive.google.com/file/d/1pIx_zrDH7rDq_qc4Rp7GuEHUKax7dHKr/view?usp=sharing
* Bugcheck Analysis *
A driver has failed to complete a power IRP within a specific time.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an IRP for too long a time
Arg2: ffff9e0d10ef9050, Physical Device Object of the stack
Arg3: ffffc70d4227f1d0, nt!TRIAGE_9F_POWER on Win7 and higher, otherwise the Functional Device Object of the stack
Arg4: ffff9e0d17c368a0, The blocked IRP
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 796
Key : Analysis.Elapsed.mSec
Value: 1744
Key : Analysis.IO.Other.Mb
Value: 12
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 21
Key : Analysis.Init.CPU.mSec
Value: 453
Key : Analysis.Init.Elapsed.mSec
Value: 11428
Key : Analysis.Memory.CommitPeak.Mb
Value: 94
Key : Analysis.Version.DbgEng
Value: 10.0.27725.1000
Key : Analysis.Version.Description
Value: 10.2408.27.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2408.27.1
Key : Bugcheck.Code.KiBugCheckData
Value: 0x9f
Key : Bugcheck.Code.LegacyAPI
Value: 0x9f
Key : Bugcheck.Code.TargetModel
Value: 0x9f
Key : Failure.Bucket
Value: 0x9F_3_IMAGE_storahci.sys
Key : Failure.Hash
Value: {21defffd-4d1f-b62d-8f72-d4892aa9cff8}
Key : Hypervisor.Enlightenments.Value
Value: 0
Key : Hypervisor.Enlightenments.ValueHex
Value: 0
Key : Hypervisor.Flags.AnyHypervisorPresent
Value: 0
Key : Hypervisor.Flags.ApicEnlightened
Value: 0
Key : Hypervisor.Flags.ApicVirtualizationAvailable
Value: 1
Key : Hypervisor.Flags.AsyncMemoryHint
Value: 0
Key : Hypervisor.Flags.CoreSchedulerRequested
Value: 0
Key : Hypervisor.Flags.CpuManager
Value: 0
Key : Hypervisor.Flags.DeprecateAutoEoi
Value: 0
Key : Hypervisor.Flags.DynamicCpuDisabled
Value: 0
Key : Hypervisor.Flags.Epf
Value: 0
Key : Hypervisor.Flags.ExtendedProcessorMasks
Value: 0
Key : Hypervisor.Flags.HardwareMbecAvailable
Value: 1
Key : Hypervisor.Flags.MaxBankNumber
Value: 0
Key : Hypervisor.Flags.MemoryZeroingControl
Value: 0
Key : Hypervisor.Flags.NoExtendedRangeFlush
Value: 0
Key : Hypervisor.Flags.NoNonArchCoreSharing
Value: 0
Key : Hypervisor.Flags.Phase0InitDone
Value: 0
Key : Hypervisor.Flags.PowerSchedulerQos
Value: 0
Key : Hypervisor.Flags.RootScheduler
Value: 0
Key : Hypervisor.Flags.SynicAvailable
Value: 0
Key : Hypervisor.Flags.UseQpcBias
Value: 0
Key : Hypervisor.Flags.Value
Value: 16908288
Key : Hypervisor.Flags.ValueHex
Value: 1020000
Key : Hypervisor.Flags.VpAssistPage
Value: 0
Key : Hypervisor.Flags.VsmAvailable
Value: 0
Key : Hypervisor.RootFlags.AccessStats
Value: 0
Key : Hypervisor.RootFlags.CrashdumpEnlightened
Value: 0
Key : Hypervisor.RootFlags.CreateVirtualProcessor
Value: 0
Key : Hypervisor.RootFlags.DisableHyperthreading
Value: 0
Key : Hypervisor.RootFlags.HostTimelineSync
Value: 0
Key : Hypervisor.RootFlags.HypervisorDebuggingEnabled
Value: 0
Key : Hypervisor.RootFlags.IsHyperV
Value: 0
Key : Hypervisor.RootFlags.LivedumpEnlightened
Value: 0
Key : Hypervisor.RootFlags.MapDeviceInterrupt
Value: 0
Key : Hypervisor.RootFlags.MceEnlightened
Value: 0
Key : Hypervisor.RootFlags.Nested
Value: 0
Key : Hypervisor.RootFlags.StartLogicalProcessor
Value: 0
Key : Hypervisor.RootFlags.Value
Value: 0
Key : Hypervisor.RootFlags.ValueHex
Value: 0
Key : SecureKernel.HalpHvciEnabled
Value: 0
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Version
Value: 10.0.19041.1
BUGCHECK_CODE: 9f
BUGCHECK_P1: 3
BUGCHECK_P2: ffff9e0d10ef9050
BUGCHECK_P3: ffffc70d4227f1d0
BUGCHECK_P4: ffff9e0d17c368a0
FILE_IN_CAB: MEMORY.DMP
FAULTING_THREAD: ffffb480c184b440
DRVPOWERSTATE_SUBCODE: 3
DRIVER_OBJECT: ffff9e0d10eba060
IMAGE_NAME: storahci.sys
MODULE_NAME: storahci
FAULTING_MODULE: fffff8024d790000 storahci
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME: System
STACK_TEXT:
ffffc70d`4227f5e0 00000000`00000000 : ffffc70d`42280000 ffffc70d`42279000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x9e
STACK_COMMAND: .process /r /p 0xfffff8024c724a00; .thread 0xffffb480c184b440 ; kb
FAILURE_BUCKET_ID: 0x9F_3_IMAGE_storahci.sys
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {21defffd-4d1f-b62d-8f72-d4892aa9cff8}
Did you recreate the installer to rule out a corrupt installer? Did you install the OS in offline mode?
https://www.asrock.com/mb/AMD/X870 Pro RS/index.asp#BIOS
Flash the BIOS to version 3.20, then clear the CMOS and then see if the issue persists.
The ram kit you picked out doesn't have AMD's E.X.P.O on it.
Are you running a RAID array?
Parts from the old build are the GPU, the Samsung...
If the older OS was on the Samsung drive, did you wipe it clean before recycling it on your new platform? Were all drives disconnected except for the one you installed the OS onto?
Yes I made the installer on my previous builder with a flash drive and I installed it in offline mode so I could make a local user.
I wasn't sure if I should use the BIOS since it was created a few days ago to fix a boot problem with x3d cpus and wanted to wait for a non-beta release. I'll flash it this weekend.
Thats something I wasn't aware of. A lot of places I look say even if its not the QVL its fine. I'll pick out some new RAM soon unless its not super important. It is running at 6000MHz
No, should I be or it thinking I am? I only use the other 2 m.2 drives for game storage and then I use the HDD for media.
The Samsung was only used for game storage and had steam and gog games on it. The m.2 drives were installed during the install because I didn't want to mess with it if I didn't have to. I see in disk D: the samsung there is a 1MB Recovery Partition but I figured that was a Samsung partition for its tools.
I updated the bios yesterday and didn't have a bsod after 10 hours of use but today when I turned on my computer from shut down I saw that I had a generic Kernel-Power error event ID 41. No new memory dump was created. I have my computer hooked up to a ups that's only 8 months old.
I also noticed theres a lot of errors for DeviceSetupManager.
Metadata staging failed, result=0x80070490 for container '{0A7A1CBC-AE89-5D7B-997A-89CDAACBEB5D}'
But from what I researched it was because the link windows uses is out of date and I can fix it manually by editing a register.
sfc/scannow still doesn't find any issues.
