[SOLVED] BSOD problem
Alibi
Hello everyone. I have been having this BSOD problem for a while now and so I thought that you guys could help. I've also just reset my PC thinking that it would help with my problem but it didn't. My minidump will be linked below. Any help given will be greatly appreciated.
Thanks In Advance
Alibi
Minidump: https://we.tl/t-S8vQWmsaw6
The reason I asked you to run it is because it collects that which you already provided and more. Below is an overview of the crashes with some data I could not have found out with the eventlog or the dumps given prior. This is useful because there are hexadecimal values like 'c0000006' and 'c000000e' that have a meaning behind them. These two specifically you can also find in my first post, they indicate an in-page error occurred and a non-existing device was specified. These two are almost always recurring in the crashes. Generally speaking, at a glimpse of data like this it tells me that there are two potential suspects, RAM and storage. Assuming your drives are healthy as indicated by the tests and scans, the RAM is the likely...
Do you have Norton AnitVirus installed on your platform? If so, uninstall that and see if the issue crops up. I'd advise you to also make sure your motherboard/laptop BIOS is on the latest version. As for your OS, you should ideally be on 21H1, you're currently on 20H1.
Used WinDbg on Windows 10, I could be wrong but I stand to be corrected.
I tried uninstalling Norton and upgrading my windows to 21H1. I also looked into the G11CD BIOS and my current version was the 0807 version which to my knowledge was the latest one for the G11CD-K which I currently use. This did although sadly not work and I got another BSOD. I have linked the new dump file below if needed.
Minidump: https://we.tl/t-ROB4zVkpy9
Having issues with decompressing a buffer because nothing valid was returned to be decompressed. I suggest checking your drive for problems.
Norton probably just was requesting data that was compressed.
Code:
3: kd> knL
 # Child-SP          RetAddr           Call Site
00 ffffca83`e6b65e78 fffff802`6fd94b6e nt!KeBugCheckEx
01 ffffca83`e6b65e80 fffff802`6fc10a83 nt!SMKM_STORE<SM_TRAITS>::SmStUnhandledExceptionFilter+0x7e
02 ffffca83`e6b65ed0 fffff802`6fbccdaf nt!`SMKM_STORE<SM_TRAITS>::SmStDirectReadIssue'::`1'::filt$0+0x22
03 ffffca83`e6b65f00 fffff802`6fbfffef nt!_C_specific_handler+0x9f
04 ffffca83`e6b65f70 fffff802`6fae6de7 nt!RtlpExecuteHandlerForException+0xf
05 ffffca83`e6b65fa0 fffff802`6fae59d6 nt!RtlDispatchException+0x297
06 ffffca83`e6b666c0 fffff802`6fc091ac nt!KiDispatchException+0x186
07 ffffca83`e6b66d80 fffff802`6fc05343 nt!KiExceptionDispatch+0x12c
08 ffffca83`e6b66f60 fffff802`6fb31620 nt!KiPageFault+0x443
09 ffffca83`e6b670f8 fffff802`6fb06490 nt!RtlDecompressBufferXpressLz+0x50
0a ffffca83`e6b67110 fffff802`6fb061d8 nt!RtlDecompressBufferEx+0x60
0b ffffca83`e6b67160 fffff802`6fb06065 nt!ST_STORE<SM_TRAITS>::StDmSinglePageCopy+0x150
0c ffffca83`e6b67220 fffff802`6fb0589c nt!ST_STORE<SM_TRAITS>::StDmSinglePageTransfer+0xa5
0d ffffca83`e6b67270 fffff802`6fb056cc nt!ST_STORE<SM_TRAITS>::StDmpSinglePageRetrieve+0x180
0e ffffca83`e6b67310 fffff802`6fb05519 nt!ST_STORE<SM_TRAITS>::StDmPageRetrieve+0xc8
0f ffffca83`e6b673c0 fffff802`6fb053d1 nt!SMKM_STORE<SM_TRAITS>::SmStDirectReadIssue+0x85
10 ffffca83`e6b67440 fffff802`6faf8468 nt!SMKM_STORE<SM_TRAITS>::SmStDirectReadCallout+0x21
11 ffffca83`e6b67470 fffff802`6fb02f2f nt!KeExpandKernelStackAndCalloutInternal+0x78
12 ffffca83`e6b674e0 fffff802`6fad0e04 nt!SMKM_STORE<SM_TRAITS>::SmStDirectRead+0xc7
13 ffffca83`e6b675b0 fffff802`6fad0838 nt!SMKM_STORE<SM_TRAITS>::SmStWorkItemQueue+0x1ac
14 ffffca83`e6b67600 fffff802`6fb039b7 nt!SMKM_STORE_MGR<SM_TRAITS>::SmIoCtxQueueWork+0xc0
15 ffffca83`e6b67690 fffff802`6fb5ae0b nt!SMKM_STORE_MGR<SM_TRAITS>::SmPageRead+0x167
16 ffffca83`e6b67700 fffff802`6fa5e0a0 nt!SmPageRead+0x33
17 ffffca83`e6b67750 fffff802`6fa5bb4d nt!MiIssueHardFaultIo+0x10c
18 ffffca83`e6b677a0 fffff802`6fa9f568 nt!MiIssueHardFault+0x29d
19 ffffca83`e6b67860 fffff802`6fc0525e nt!MmAccessFault+0x468
1a ffffca83`e6b67a00 00007ffd`199fc33f nt!KiPageFault+0x35e
1b 0000000b`5fdff100 00000000`00000000 0x00007ffd`199fc33f
3: kd> .exr 0xffffca83e6b66eb8
ExceptionAddress: fffff8026fb31620 (nt!RtlDecompressBufferXpressLz+0x0000000000000050)
   ExceptionCode: c0000006 (In-page I/O error)
  ExceptionFlags: 00000000
NumberParameters: 3
   Parameter[0]: 0000000000000000
   Parameter[1]: 000002516e4023e0
   Parameter[2]: 00000000c000000e
Inpage operation failed at 000002516e4023e0, due to I/O error 00000000c000000e
3: kd> !stack -p
Call Stack : 28 frames
## Stack-Pointer    Return-Address   Call-Site
00 ffffca83e6b65e78 fffff8026fd94b6e nt!KeBugCheckEx+0
    Parameter[0] = 0000000000000154
    Parameter[1] = ffff8f02c12b2000
    Parameter[2] = ffffca83e6b65f30
    Parameter[3] = 0000000000000002
01 ffffca83e6b65e80 fffff8026fc10a83 nt!SMKM_STORE<SM_TRAITS>::SmStUnhandledExceptionFilter+7e
    Parameter[0] = ffff8f02c12b2000
    Parameter[1] = ffffca83e6b65f30
    Parameter[2] = 0000000000000002
    Parameter[3] = (unknown)
02 ffffca83e6b65ed0 fffff8026fbccdaf nt!`SMKM_STORE<SM_TRAITS>::SmStDirectReadIssue'::`1'::filt$0+22
    Parameter[0] = ffffca83e6b65f30
    Parameter[1] = ffffca83e6b673c0
    Parameter[2] = (unknown)
03 ffffca83e6b65f00 fffff8026fbfffef nt!_C_specific_handler+9f
    Parameter[0] = ffffca83e6b66eb8
    Parameter[2] = 0000000000000000
    Parameter[3] = ffffca83e6b66530
04 ffffca83e6b65f70 fffff8026fae6de7 nt!RtlpExecuteHandlerForException+f
    Parameter[1] = ffffca83e6b66eb8
    Parameter[2] = ffffca83e6b666f0
05 ffffca83e6b65fa0 fffff8026fae59d6 nt!RtlDispatchException+297
    Parameter[0] = (unknown)
    Parameter[1] = (unknown)
06 ffffca83e6b666c0 fffff8026fc091ac nt!KiDispatchException+186
    Parameter[0] = b33cab7225100e87
    Parameter[1] = ffffca83e6b61000
    Parameter[2] = 18350787431f6479
    Parameter[3] = 72a40efbb8371cfa
07 ffffca83e6b66d80 fffff8026fc05343 nt!KiExceptionDispatch+12c
08 ffffca83e6b66f60 fffff8026fb31620 nt!KiPageFault+443
    Parameter[0] = ffffa1804e790000
    Parameter[1] = ffffa1804e790000
    Parameter[2] = 000002516e4023e0
    Parameter[3] = 00000000000006c6
09 ffffca83e6b670f8 fffff8026fb06490 nt!RtlDecompressBufferXpressLz+50
0a ffffca83e6b67110 fffff8026fb061d8 nt!RtlDecompressBufferEx+60
    Parameter[1] = ffffa1804e790000 <-- pointer to buffer
    Parameter[2] = 0000000000001000
    Parameter[3] = 000002516e4023e0
0b ffffca83e6b67160 fffff8026fb06065 nt!ST_STORE<SM_TRAITS>::StDmSinglePageCopy+150
    Parameter[0] = ffff8f02c12b2050
    Parameter[1] = 0000000000000000
    Parameter[2] = 000002516e4023e1
    Parameter[3] = ffffa1804e790000
0c ffffca83e6b67220 fffff8026fb0589c nt!ST_STORE<SM_TRAITS>::StDmSinglePageTransfer+a5
    Parameter[3] = ffff8f02d40c5c10
0d ffffca83e6b67270 fffff8026fb056cc nt!ST_STORE<SM_TRAITS>::StDmpSinglePageRetrieve+180
0e ffffca83e6b67310 fffff8026fb05519 nt!ST_STORE<SM_TRAITS>::StDmPageRetrieve+c8
    Parameter[0] = ffffca83e6b67599
    Parameter[1] = ffff8f02d4ee0000
    Parameter[2] = ffff8f02d40c5c10
0f ffffca83e6b673c0 fffff8026fb053d1 nt!SMKM_STORE<SM_TRAITS>::SmStDirectReadIssue+85
10 ffffca83e6b67440 fffff8026faf8468 nt!SMKM_STORE<SM_TRAITS>::SmStDirectReadCallout+21
11 ffffca83e6b67470 fffff8026fb02f2f nt!KeExpandKernelStackAndCalloutInternal+78
12 ffffca83e6b674e0 fffff8026fad0e04 nt!SMKM_STORE<SM_TRAITS>::SmStDirectRead+c7
13 ffffca83e6b675b0 fffff8026fad0838 nt!SMKM_STORE<SM_TRAITS>::SmStWorkItemQueue+1ac
    Parameter[1] = ffff8f02d40c5c10
14 ffffca83e6b67600 fffff8026fb039b7 nt!SMKM_STORE_MGR<SM_TRAITS>::SmIoCtxQueueWork+c0
15 ffffca83e6b67690 fffff8026fb5ae0b nt!SMKM_STORE_MGR<SM_TRAITS>::SmPageRead+167
    Parameter[1] = ffffca83e6b67730
    Parameter[2] = ffff8f02ce7eca70
16 ffffca83e6b67700 fffff8026fa5e0a0 nt!SmPageRead+33
    Parameter[0] = ffff8f02ce7ec9c0
    Parameter[1] = ffff8f02ce7eca70
    Parameter[2] = ffff8f02ce7ec980
    Parameter[3] = ffff8f02ce7ec9b0
17 ffffca83e6b67750 fffff8026fa5bb4d nt!MiIssueHardFaultIo+10c
18 ffffca83e6b677a0 fffff8026fa9f568 nt!MiIssueHardFault+29d
19 ffffca83e6b67860 fffff8026fc0525e nt!MmAccessFault+468 (perf)
1a ffffca83e6b67a00 00007ffd199fc33f nt!KiPageFault+35e
    Parameter[0] = 0000013be2f90ad0
    Parameter[1] = 0000013be2f90a00
    Parameter[2] = 0000013be2f90ac0
    Parameter[3] = 0000000000001000
3: kd> dd ffffa1804e790000
ffffa180`4e790000  ????????`???????? ????????`????????
ffffa180`4e790010  ????????`???????? ????????`????????
ffffa180`4e790020  ????????`???????? ????????`????????
ffffa180`4e790030  ????????`???????? ????????`????????
ffffa180`4e790040  ????????`???????? ????????`????????
ffffa180`4e790050  ????????`???????? ????????`????????
ffffa180`4e790060  ????????`???????? ????????`????????
ffffa180`4e790070  ????????`???????? ????????`????????
So I ran CHKDSK on both of my drives and they both came out clean. I also ran the sfc /scannow command returning "Windows Resource Protection did not find any integrity violations." After that, I downloaded the Western Digital Dashboard thinking that the S.M.A.R.T feature could help me. This feature did although cause a blue screen instead. The programs that I checked all say that my drives are "OK". Any help is appreciated.
SFC and DISM have no effect. DISM is meant to fix corruption that prevents SFC from working correctly. SFC is designed to fix problems to make sure Windows keeps running. Neither of them does anything with the drive.
Chkdsk does do something with the drive, but only partial. It only fixes problems in the filesystem, albeit it does work with sectors too.
Let's have a look at the eventlogs. Please run this command in a command prompt, it generates the file eventlog.txt on your desktop. Please upload this file.
Code:
wevtutil qe System /f:text > "%USERPROFILE%\Desktop\eventlog.txt"
Did you by any chance check more programs for the SMART than have been mentioned here?
Asking because of these events
Code:
   2021-08-07T15:07:29.6510000Z        The IO operation at logical block address 0x1367cd8 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:07:30.1610000Z        The IO operation at logical block address 0x32bba8 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:12:52.7850000Z        The IO operation at logical block address 0x668af8 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:12:53.8040000Z        The IO operation at logical block address 0x29323b0 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:12:54.3140000Z        The IO operation at logical block address 0x27ecf50 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:12:54.3400000Z        The IO operation at logical block address 0x2d4cd48 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:12:55.5410000Z        The IO operation at logical block address 0x274270 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:12:56.5890000Z        The IO operation at logical block address 0x291c630 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:12:57.6100000Z        The IO operation at logical block address 0x28deb40 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:12:58.6350000Z        The IO operation at logical block address 0x293f598 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:13:29.1570000Z        Reset to device, \Device\RaidPort0, was issued.
   2021-08-07T15:14:06.4710000Z        The IO operation at logical block address 0x2915f98 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:06.9860000Z        The IO operation at logical block address 0x290b9d0 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:08.0110000Z        The IO operation at logical block address 0x28a91a8 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:42.2270000Z        The IO operation at logical block address 0x2c92d10 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:43.4060000Z        The IO operation at logical block address 0x28a9228 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:43.4850000Z        The IO operation at logical block address 0x668a78 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:47.2140000Z        The IO operation at logical block address 0x2a9dbf8 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:47.9780000Z        The system failed to flush data to the transaction log. Corruption may occur in VolumeId: C:, DeviceName: \Device\HarddiskVolume3.
           Failure status: The I/O device reported an I/O error.
           Device GUID: {ecac3360-b0ad-5078-c780-f8a349072dff}
           Device manufacturer:
           Device model: SanDisk SD8SBAT128G1002
           Device revision: Z2317002
           Device serial number: 165351404295
           Bus type: SATA
           Adapter serial number:
   2021-08-07T15:14:48.4910000Z        The IO operation at logical block address 0x2a82938 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:49.5200000Z        The IO operation at logical block address 0x677a68 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:53.6250000Z        The IO operation at logical block address 0x9f2c30 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:54.1440000Z        The IO operation at logical block address 0x28f1af0 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:56.1930000Z        The IO operation at logical block address 0x677a68 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:56.7050000Z        The IO operation at logical block address 0xd820d0 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:57.2250000Z        The IO operation at logical block address 0x2ab9088 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:57.7400000Z        The IO operation at logical block address 0x287bca8 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:14:59.7940000Z        The IO operation at logical block address 0x13687d8 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:15:00.2960000Z        The IO operation at logical block address 0xa98850 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T15:15:31.8430000Z        Reset to device, \Device\RaidPort0, was issued.
   2021-08-07T19:50:06.2540000Z        The IO operation at logical block address 0x6c0de0 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T19:50:12.2730000Z        The IO operation at logical block address 0x67bc50 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T19:52:25.4780000Z        The IO operation at logical block address 0x67c388 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:12:22.9670000Z        The IO operation at logical block address 0x668b38 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:13:48.5190000Z        The IO operation at logical block address 0x3435db0 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:14:07.3510000Z        The IO operation at logical block address 0x34483b0 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:14:37.5010000Z        The IO operation at logical block address 0x2d38bb0 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:14:37.7940000Z        The IO operation at logical block address 0x309e848 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:14:41.9350000Z        The IO operation at logical block address 0x2851120 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:15:16.6440000Z        The IO operation at logical block address 0x2d96178 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:15:16.7690000Z        The IO operation at logical block address 0x2f2f848 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:15:16.9900000Z        The IO operation at logical block address 0x2aa4308 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:15:17.1700000Z        The IO operation at logical block address 0x2b04998 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:15:17.3360000Z        The IO operation at logical block address 0x6733b8 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:17:02.4960000Z        The IO operation at logical block address 0x29416d8 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:17:23.6920000Z        The IO operation at logical block address 0x2d51e58 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:17:24.2190000Z        The IO operation at logical block address 0x332e860 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:17:24.7330000Z        The IO operation at logical block address 0x3311360 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:17:25.2460000Z        The IO operation at logical block address 0x3311560 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:17:25.7490000Z        The IO operation at logical block address 0x3311760 for Disk 0 (PDO name: \Device\00000036) was retried.
   2021-08-07T20:18:33.8340000Z        The IO operation at logical block address 0x2fc8c48 for Disk 0 (PDO name: \Device\00000036) was retried.
So I've ran SMART a few times from within the Western Digital Dashboard, but sadly with all of them causing a BSOD within a few minutes. I haven't used any other programs to run SMART. I don't recall having used it in the command prompt either if that even is possible.
The reason I asked you to run it is because it collects that which you already provided and more. Below is an overview of the crashes with some data I could not have found out with the eventlog or the dumps given prior. This is useful because there are hexadecimal values like 'c0000006' and 'c000000e' that have a meaning behind them. These two specifically you can also find in my first post, they indicate an in-page error occurred and a non-existing device was specified. These two are almost always recurring in the crashes. Generally speaking, at a glimpse of data like this it tells me that there are two potential suspects, RAM and storage. Assuming your drives are healthy as indicated by the tests and scans, the RAM is the likely suspect currently.
I suggest following this guide to run MemTest86.
Code:
2021-08-13 08:29    Windows Error Reporting    Fault bucket 0x154_c0000006_c000000e_nt!ExFreePool, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: b3826e7c-baeb-451e-ab68-9ce1b3b0d432&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: 154&#x000d;&#x000a;P2: ffffae0f98370000&#x000d;&#x000a;P3: ffffe60b0b935910&#x000d;&#x000a;P4: 2&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\081321-6296-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-26125-0.sysdata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER78C9.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER78DA.tmp.xml&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_154_3c74c88d70c23117b7ce254cd50fad990ad14f5_00000000_cab_0424a07f-8827-4e8d-9d57-18fa2e595dc8&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: c7408fa7-d16a-4160-bde7-cc1f6355b34d&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-11 12:06    Windows Error Reporting    Fault bucket 0xEF_svchost.exe_BUGCHECK_CRITICAL_PROCESS_c0000005_BAD_IP_nt!PspCatchCriticalBreak, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: 656adac1-e483-4de1-b028-868531e42fba&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: ef&#x000d;&#x000a;P2: ffffbf8749e0a080&#x000d;&#x000a;P3: 0&#x000d;&#x000a;P4: 0&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\081121-5984-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-7578-0.sysdata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER35D5.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER35E5.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3604.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3614.tmp.txt&#x000d;&#x000a;\\?\C:\Windows\Temp\WER5A46.tmp.WERDataCollectionStatus.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_ef_7dbdba72e94ca91edc4887a7a73ace6b663341_00000000_cab_e6b08440-036c-4d9b-8857-57eac4e81aef&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: e2730f7b-b4b4-4808-b50c-8737a41ed474&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-11 07:36    Windows Error Reporting    Fault bucket 0xEF_services.exe_BUGCHECK_CRITICAL_PROCESS_IOERR_c000000e, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: 8cf647d3-605c-4358-85c2-e0d55757913d&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: ef&#x000d;&#x000a;P2: ffffa709207ca140&#x000d;&#x000a;P3: 0&#x000d;&#x000a;P4: 0&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\081121-4750-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-6343-0.sysdata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2B65.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2B85.tmp.xml&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_ef_d6d4bc689267f8f544bab765e94a6e3839124b9_00000000_cab_d2df90f4-96c1-4a8e-a1d2-87273b7a560b&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: c913e6e0-8fc4-4efb-aa55-e23e917a9831&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-11 06:30    Windows Error Reporting    Fault bucket 0xEF_services.exe_BUGCHECK_CRITICAL_PROCESS_IOERR_c000000e, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: 032faa43-91ad-4926-8dcb-01803d47a015&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: ef&#x000d;&#x000a;P2: ffff94053fb2c140&#x000d;&#x000a;P3: 0&#x000d;&#x000a;P4: 0&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\081021-5937-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-7593-0.sysdata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3567.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3568.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3596.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3597.tmp.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_ef_6e292e965526b8eca8713b4336a1af6812a263e_00000000_cab_aa30c240-c6fe-4d84-9174-d5ceb86d4ad8&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: 3e649251-ffcb-4107-98b8-4cc9a82a1637&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-10 19:18    Windows Error Reporting    Fault bucket 0xEF_svchost.exe_BUGCHECK_CRITICAL_PROCESS_IOERR_c000000e, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: 200c6cde-08c6-47f7-addc-03708d0e08fa&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: ef&#x000d;&#x000a;P2: ffffa80b61c322c0&#x000d;&#x000a;P3: 0&#x000d;&#x000a;P4: 0&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\081021-6203-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-7781-0.sysdata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3BA1.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3BB2.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3BE0.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3BE1.tmp.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_ef_f94a93dc46196284b53abfc24e284cbfa07bc2_00000000_cab_04ece96e-7b8a-4ed7-8268-f598a2be2134&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: 605a8011-55e0-41a5-8dc7-3f250860f539&#x000d;&#x000a;Report Status: 268435460&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-10 13:46    Windows Error Reporting    Fault bucket 0xEF_svchost.exe_BUGCHECK_CRITICAL_PROCESS_c0000005_nt!PspCatchCriticalBreak, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: b0966254-2bdd-46f1-9ec6-0b90fea1d952&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: ef&#x000d;&#x000a;P2: ffffd28475216080&#x000d;&#x000a;P3: 0&#x000d;&#x000a;P4: 0&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\081021-5718-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-11328-0.sysdata.xml&#x000d;&#x000a;\\?\C:\Windows\MEMORY.DMP&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4093.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER40A3.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER40C2.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER40D2.tmp.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_ef_8d62b786955bc78728376a5544d60727a1ba8ef_00000000_cab_f74ce2ce-df66-478c-be9f-b4c615a8e608&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: 3d971456-8893-499e-8130-2df3d249b3cb&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-10 13:37    Windows Error Reporting    Fault bucket 0xEF_services.exe_BUGCHECK_CRITICAL_PROCESS_IOERR_c000000e, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: 596c3c55-13b1-419c-ab6a-7ac1f53c2be3&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: ef&#x000d;&#x000a;P2: ffff9e044f321140&#x000d;&#x000a;P3: 0&#x000d;&#x000a;P4: 0&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\081021-6281-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-12859-0.sysdata.xml&#x000d;&#x000a;\\?\C:\Windows\MEMORY.DMP&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4872.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4873.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4892.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER48A2.tmp.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_ef_17bd34c21229bb01e324fd7ffe52e7b5e126_00000000_cab_e34b1c94-04db-4ef5-bf61-2da65fe2e0e7&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: 0b2e059a-a048-4645-aea5-b83cbf42ad56&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-09 08:24    Windows Error Reporting    Fault bucket 0xEF_services.exe_BUGCHECK_CRITICAL_PROCESS_IOERR_c000000e, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: 2d7f8aca-f7e3-4719-8cfb-f0ef8e8f1cb2&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: ef&#x000d;&#x000a;P2: ffffb30faa0d6140&#x000d;&#x000a;P3: 0&#x000d;&#x000a;P4: 0&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\080921-7968-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-13656-0.sysdata.xml&#x000d;&#x000a;\\?\C:\Windows\MEMORY.DMP&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER445C.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER446C.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER449A.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER44AB.tmp.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_ef_f9f8b9a7aceec1ea57b8b5e58908f226af4e439_00000000_cab_43c7b52c-3dfa-4a7c-baf0-5d9c6574875c&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: 4f612e16-8f78-4372-b05d-a94f413868ab&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-09 08:07    Windows Error Reporting    Fault bucket 0xEF_svchost.exe_BUGCHECK_CRITICAL_PROCESS_IOERR_c000000e, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: 3e23ff94-ff3e-49eb-8fbc-d921a1dd2daa&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: ef&#x000d;&#x000a;P2: ffff88046d8222c0&#x000d;&#x000a;P3: 0&#x000d;&#x000a;P4: 0&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\080921-6406-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-11578-0.sysdata.xml&#x000d;&#x000a;\\?\C:\Windows\MEMORY.DMP&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3E8F.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3EA0.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3EBE.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3ECF.tmp.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_ef_1554b87851fff1705d1b503119fc70cf2016a63b_00000000_cab_d6061d43-825e-4dd9-9bf3-8d615352d8dc&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: a3348c91-7e5d-463a-beef-9bf5448488f7&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-09 08:01    Windows Error Reporting    Fault bucket 0xEF_smss.exe_BUGCHECK_CRITICAL_PROCESS_IOERR_c000000e, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: c6261946-1cb7-449b-9928-6681c3fe87de&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: ef&#x000d;&#x000a;P2: ffff80843007c040&#x000d;&#x000a;P3: 0&#x000d;&#x000a;P4: 0&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\080921-6703-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-12343-0.sysdata.xml&#x000d;&#x000a;\\?\C:\Windows\MEMORY.DMP&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3F7A.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3F7B.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3F99.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3FA9.tmp.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_ef_6df652c63b5b21dd3fcb8d6b8bad43bf84d392f_00000000_cab_0a7d643f-9072-40e4-85b7-4f63fb8af05f&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: 5f503d85-8e24-4e32-819f-435dda61866a&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-08 18:02    Windows Error Reporting    Fault bucket 0x154_c0000006_c000000e_nt!RtlDecompressBufferXpressLz, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: 7fd94d1e-f618-4921-8949-91c1041962c4&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: 154&#x000d;&#x000a;P2: ffff8f02c12b2000&#x000d;&#x000a;P3: ffffca83e6b65f30&#x000d;&#x000a;P4: 2&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\080821-5578-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-10593-0.sysdata.xml&#x000d;&#x000a;\\?\C:\Windows\MEMORY.DMP&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3AE6.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3AE7.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3B05.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3B06.tmp.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_154_eaad6174c2b0a2786ba9d84aae7f76e2a9f8cf_00000000_cab_b2811329-8814-4b1d-8079-0b72bafeab06&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: 11362b0c-5fec-4107-9f5b-dd490eafb232&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-08 11:07    Windows Error Reporting    Fault bucket 0xEF_svchost.exe_BUGCHECK_CRITICAL_PROCESS_IOERR_c000000e, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: b80f8e44-27fe-43d4-8adc-7ba3c1109e12&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: ef&#x000d;&#x000a;P2: ffffbb8a9bbd02c0&#x000d;&#x000a;P3: 0&#x000d;&#x000a;P4: 0&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\080821-8765-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-14593-0.sysdata.xml&#x000d;&#x000a;\\?\C:\Windows\MEMORY.DMP&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4A18.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4A19.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4A38.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4A48.tmp.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_ef_2f3f3e14f27696a4b38618e629eeed4c4da23c_00000000_cab_f05653a9-f60a-4582-a741-bf5cd6458b4a&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: 707c6590-964e-4bdb-a403-bd212314255f&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-08 11:07    Windows Error Reporting    Fault bucket 0x154_c0000006_c000000e_SYMEFASI64!unknown_function, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: 106fe6a3-dc47-41d7-95e9-3fac7cf5cd88&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: 154&#x000d;&#x000a;P2: ffffb301a340f000&#x000d;&#x000a;P3: ffff868878ac0580&#x000d;&#x000a;P4: 2&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\080821-7046-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-15062-0.sysdata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4BFD.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4C0D.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4C1C.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER4C6B.tmp.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_154_73d68875cb8bfa77d2ed3749c0eff6aaa69a62_00000000_cab_52bb6f29-f30c-40d6-8adb-0bcadbeee7d4&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: 90f7c185-633d-4ace-8b8b-33f64ef6c330&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
2021-08-08 09:04    Windows Error Reporting    Fault bucket 0x3B_c0000006_nt!HvpGetCellPaged, type 0&#x000d;&#x000a;Event Name: BlueScreen&#x000d;&#x000a;Response: Not available&#x000d;&#x000a;Cab Id: da93ff73-fa27-4a33-9969-73d4a1be6946&#x000d;&#x000a;&#x000d;&#x000a;Problem signature:&#x000d;&#x000a;P1: 3b&#x000d;&#x000a;P2: c0000006&#x000d;&#x000a;P3: fffff804656cbbe2&#x000d;&#x000a;P4: ffff828a0e4fc470&#x000d;&#x000a;P5: 0&#x000d;&#x000a;P6: 10_0_19043&#x000d;&#x000a;P7: 0_0&#x000d;&#x000a;P8: 768_1&#x000d;&#x000a;P9: &#x000d;&#x000a;P10: &#x000d;&#x000a;&#x000d;&#x000a;Attached files:&#x000d;&#x000a;\\?\C:\Windows\Minidump\080821-7578-01.dmp&#x000d;&#x000a;\\?\C:\Windows\TEMP\WER-13656-0.sysdata.xml&#x000d;&#x000a;\\?\C:\Windows\MEMORY.DMP&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER46DC.tmp.WERInternalMetadata.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER46FC.tmp.xml&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER471B.tmp.csv&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER472B.tmp.txt&#x000d;&#x000a;&#x000d;&#x000a;These files may be available here:&#x000d;&#x000a;\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_3b_2c13498d81a23c3dd7c559fcd5babf102b6c963_00000000_cab_c31788bc-5ca8-4352-ae6f-1a5a35a7ccbb&#x000d;&#x000a;&#x000d;&#x000a;Analysis symbol: &#x000d;&#x000a;Rechecking for solution: 0&#x000d;&#x000a;Report Id: 71acd83f-e1ba-4e9a-9a76-57b67c165b9c&#x000d;&#x000a;Report Status: 268435456&#x000d;&#x000a;Hashed bucket: &#x000d;&#x000a;Cab Guid: 0
