[SOLVED] BTC TB250 Pro - Display issue No signal
Hello there, I have been in this problen since few weeks. But I was not able to figure things out.
My Specs
Mobo: TB250-BTC PRO
CPUIntel Pentium Gold G5420 (4M Cache, 3.80GHz)
HD:Crucial BX500 120GB 3D NAND SATA
Power:Antec 13000 Signature PLATINUM
Avobe I have mentioned the parts that I am using to build the mining rig. I am not getting a display. I tried two ways
1. without the graphics card I directly connected the 24 DVI pin to the monitor, (I was using a frontec LED monitor which has 15 pin DVI) so I hav to use a 24 to 15 adaptor to connect it. But as I said in this step this didnt work, and there was no display. showing no signal.
2. I connected 1050 Ti GPU directly to the PEX16_1 slot and then connected the hdmi to the GUP and to the monitor, which didnt work. I also tried the DVI slots from the GPU to the monitor, but didnt work.
3. I also tried step 2 both the DVI and the HDMI and, but the only diference is I connected the GPU 1050 Ti through a riser (Pi+ Gold edition/ 009S Plush / 8 capacitor 16x to 1x) where I connected the riser slot in the same PEX16_1 slot. But this also didnt work.
I just want to where I am doing wrong
There is also another thing I wan to know is when I am connecting the CPU power cable to the PSU the Board is not starting. after disconnecting this cable the board is starting.
Thanks in Advance
Thanks for the reply. I am kingd of new to this.
so it is the CPU that I have got wrong?
Does the ram effect ? I am using Crucial Ballistix RGB 3200 MHz.
