BTX Power Supply Support motherboard
Awan_77
Commendable
Aug 7, 2016
70
BTX power Supply Motherboard can be hendle the ATx Powersupply explain me and how to fix it btx to atx power suppply. plz help my motherboard is btx. and i am upgrade the powersupply 650w but all powersupply is atx plz help me..
There is no such thing as a BTX power supply, BTX is a form factor, in the simplest terms the ports and slots of the motherboard are reversed. However BTX motherboards generally will have a 20 or 24 pin connector which is the same as ATX. HOWEVER If you have a Dell or HP motherboard they may have proprietary PSU connections, which do not conform to that 20/24 pin standard. Some adaptors are available, but if not you may be out of luck.
Bro My motherboard is btx and i am upgrade the Power supply 650watt but the problem is occurred the power supply is btx type and every power supply is atx. my computer model is HP Elite Desk 800 G2 Tower. i am very upset plz solution me ho to upgrade the power supply in this model.
Thanks for letting me know the specific system.
As I said there is no such thing as a BTX power supply. That HP has its own proprietary PSU setup and unfortunately there is no adapter nor is there a way to get a PSU other than the stock HP PSU to work with it.
