[SOLVED] Budget 5600G mATX - Parts List - Upgradability?
EzTec
421
Hey everyone so my parts list is below, I'm pretty limited as I'm living in Colombia so if I buy on amazon, we need this to be under 200USD or else I pay additional taxes and that wouldn't exactly promote a budget build :) I've already purchased everything below either on Amz or here used @ a bit of a markup.
No plans on streaming, I really wanted to just casually play some games like GTA V, Diablo 4, maybe some FPS games. I plan on maybe going for a 1650 super or 1660 in the next couple of months to give me some better performance but I wanted to post my parts list here and make sure I didn't make any mistakes or maybe I can swap something out as soon as I get it.
Some concerns are the M.2, it's a Sata III so I'm not sure If I'm missing out really on a lot of speed differences, the Ram is a 3600 CL 18 which from what I've seen isn't too bad and really just those two things. I got the specific motherboard because of the Bios Flashback... no older chips to upgrade a Bios if I get a different board that may not support the 5600G.
PCPartPicker Part List
CPU | AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor | $179.98 @ Amazon
Motherboard | Asus Prime B450M-A II Micro ATX AM4 Motherboard | $79.98 @ Amazon
Memory | Team T-Create Expert 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory | $61.99 @ Amazon
Storage | Team MS30 512 GB M.2-2280 Solid State Drive | $49.99 @ Newegg
Case | Thermaltake S100 MicroATX Mini Tower Case | $55.00
Power Supply | EVGA BQ 500 W 80+ Bronze Certified Semi-modular ATX Power Supply | $42.00
Case Fan | Cooler Master SickleFlow 62 CFM 120 mm Fans 3-Pack | $31.00
Headphones | SteelSeries Arctis 1 Headset | $25.00
Custom | Ubit 802.11 AC Bluetooth4.2 2.4Ghz-300Mbps/5Ghz-867Mbps PCIE Wireless WiFi Network Card Dual Band Gigabit Adapter,Pci-e Wireless WI-FI Adapter Network Card for PC(WIE8260) | $19.95 @ Amazon
Total | $544.89
I would go with a 500 series chipset, even if it is the A520, as it was made for Zen 3. 3600 CL18 doesn't perform any different than 3200 CL16, so you can save a few $ there. I would choose a case with better airflow. Definitely go with a higher quality power supply. Be prepared to get more storage, asap. Games take up a lot of space, and you do not want to run an SSD near it's capacity. You may be able to get a much better NVME drive, for the price of that sata one.
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor ($179.98 @ Amazon)
Motherboard: Gigabyte B550M DS3H AC Micro ATX AM4 Motherboard ($109.99 @ Amazon)
Memory: Silicon Power 16 GB (2 x 8 GB) DDR4-3200 CL16...
Total | $544.89
Just a pref.
I would not get a psu with less than a 5yr warranty.
Reactions: EzTec
Memory: Silicon Power 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($54.97 @ Amazon)
Storage: Western Digital Blue SN570 500 GB M.2-2280 NVME Solid State Drive ($49.99 @ Amazon)
Case: Thermaltake Versa H18 MicroATX Mini Tower Case ($54.99 @ Walmart)
Power Supply: Corsair CXF 550 W 80+ Bronze Certified Fully Modular ATX Power Supply ($64.98 @ Amazon)
Case Fan: Cooler Master SickleFlow 62 CFM 120 mm Fans 3-Pack ($31.00)
Headphones: SteelSeries Arctis 1 Headset ($25.00)
Total: $570.90
Generated by PCPartPicker 2022-05-02 10:39 EDT-0400
Reactions: EzTec
What have you purchased already?
No way the total can be under $200.
A m.2 ssd in sata III mode will perform well.
You probably cant tell the difference any more than these guys did:
View: https://www.youtube.com/watch?v=4DKLA7w9eeA
Well I've purchased everything in the Parts list and $200??? ohh.. I was referring to total cost in the cart, I have multiple orders each under 200 or I'd be charged quite a lot in taxes which I could avoid :) my total build as shown above is $544.89.
I was just watching some videos about Sata III M.2 vs. a faster NVME and yeah, the speed at least when launching games or apps isn't very noticeable which is fine, I was about to go spending a bit more money for nothing :)
