Build advice for a 1080p gaming and animation & video editing/rendering build
cannon_dt
127
Guys,
Turning to you guys again for some build advice, please do lend me your expert opinions
I am building a PC for my friend and the requirements are as follows
- do some 1080p gaming
- animation and multi media tasks including video editing / rendering
- softwares include Illustrator, Photoshop, Premiere Pro, Audition, Flash, After effects, 3Ds Max, Maya.
Budget is around 60K (dont need a monitor and kb/m, all other components needed)
Having just built a gaming PC, I know that the i5 would suffice for all 1080p gaming needs. But given that video editing etc and animation is not my forte, I am turning to you experts for advice. I have included as much information as I can in terms of tasks and softwares to be used.
If there is any other information that is needed please do let me know - I primarily need advice on the CPU/MB and GPU front. I assume the rest would fall into place once those core components are decided. Also given that I stay in India, my budget is in INR. I know that the US prices are much more competitive but I assume that the 60k budget would suffice. Please do give suggestions for all components if that is more sensible in terms of assembling the whole system.
Peace,
Ananth
PS : Just to confirm, this is a build from scratch, no existing parts that can be reused in the build.
The 7700k would be good, but the 1600 is going to be better. 12 threads vs 8. The 1700 beats Intel's 6 core cpu, in such tasks, and holds its own pretty well vs the $1000 8 core Intels, clock for clock. Price/performance, for video editing, Ryzen wins hands down. The Ryzen 7 would be more than 2k less, as you could use the stock cooler, for now, and that you could use a less expensive B350 board, unless you absolutely had to have SLI. Given the fact that the GTX 1060 isn't SLI capable, I do not see that being the case here.
It's best for gaming but if you want good video editing get one of the ryzen 1600 cpus
The 1600 is the best all around CPU, for your intended uses. Gaming performance is acceptable, and will outperform an i5 in video editing. If you stick with the 1060, the 520w should be ok. I was thinking more along the lines of an i7/GTX 1070. Too many threads to keep up with, so little time.
Ha, I know.
Like I said the 1070 is 17K more than the 1060. That is what is really making me reluctant.
How about this for a tradeoff - the 7700k instead of the 1600 but keep the GPU at 1060. Does that provide any tangible benefits? I am just trying to work out all possible combinations and their respective cost effectiveness
Thanks man. I was just not sure if the z170 supports OC, the wiki seems to think only the z270 supports OC and me being on a tight budget wanted to make sure that I was spending money on the right component
I think I would still be inclined to say Ryzen 5 1600.
http://www.guru3d.com/articles_pages/amd_ryzen_5_1600_review,12.html
index.php
Real world speeds by real users. If you want the 2nd fastest consumer CPU in the world you get the i7 7700k if you want the 34th fastest CPU in the world you get the Ryzen 5 1600X. Even the Intel Core i5-7600K for $240 beats the Ryzen 5 in effective speed. stop posting synthetic benchmarks.
http://cpu.userbenchmark.com/
I am now totally confused.
The Ryzen 7 and i7 7700K are very comparable in prices. So if I prioritize my budget then I have to go down to the 1600 or 1600x
Considering that all other parameters in terms of requirements remain the same, what should I be investing in, also in terms of longevity and not having to upgrade very soon. There are just too many things and too many conflicting opinions - please do help with the CPU. I am certainly investing in a 1060 6GB GPU, so considering that what CPU would be optimal for my needs both in terms of performance and budget???
This is a real world comparison by real users, between the 2 CPU's the i7 7700k is way faster. And it can be overclocked past 5Ghz
http://cpu.userbenchmark.com/Compare/Intel-Core-i7-7700K-vs-AMD-Ryzen-5-1600/3647vs3919
For making videos and for steaming and/or editing, the 1600 would do a slightly better job in those areas, but when it comes to highly demanding tasks that benefit from strong multi cores like gaming, if you are gaming at 1080p or higher resolution specially in 4k, the 7700k will give you better performance out of a high end graphics card like the gtx 1070 or above. if you do go ryzen though, dont buy an x model, its a waste of money. the overclocking on ryzen is rather weak and since they are all unlocked the 1600 can simply be OCed to 1600x speeds. In single core aplications the i7 700K is 44% faster than the Ryzen 1600x and in multi threaded applications the Ryzen 5 1600x is only 11% faster than the i7 7700K. And in raw performance the core i7 7700K is 4% faster than the Ryzen 5 1600x. But remember the numbers get better for the i7 since it can be overclocked past 5Ghz
Synthetic performance index
AMD Ryzen 5 1600X100% Intel Core i7-7700K104%
Single thread performance index
AMD Ryzen 5 1600X100% Intel Core i7-7700K144%
Multi thread performance index
AMD Ryzen 5 1600X111% Intel Core i7-7700K100%
http://hwbench.com/cpus/amd-ryzen-5-1600x-vs-intel-core-i7-7700k
Hmm nice budget I think AMD has 3500$ video cards based on newest GCN tech for rendering and sure you can use it for gaming.
Crossfire them
For CPU wait for AMDs server CPUs the "threadrippers" If that really is the budget go all out I guess, RAID 10 a bunch of high capacitys SSDs
THE BUDGET IS NOT IN US DOLLARS read the thread before posting nonsense.
@YoAndy
Agreed about the 1070 and the 7700K but bear in mind that the I have a fixed GPU of 1060 6GB.
So if the GPU is a non variant, then would the 7700K be an overkill in terms of its potential.
Also from a tasks perspective it is equal - both gaming at 1080p and the use of the softwares I mentioned above (multi media, video editing using Illustrator, Photoshop, Premiere Pro, Audition, Flash, After effects, 3Ds Max, Maya) - so considering this I assume you would still recommend the 7700K right. From a budget perspective the 1700 is not in the race as it is similarly priced to the 7700K. So the only toss up is between the 1600 (1600x is not in the offing like you said!) and 7700K. So what triumphs here - budget or performance?????
NM was multitasking I see so about a grand in US dolla? Can still get a profesional AMD card but lower tier, forget about RAID anything
Like I said before, if I have to choose between the 2 I'll personally go for the i7 7700K. Is not only a far superior CPU on a more mature platform but the hardware has better optimization and it has way better software support too and if you are planning on using windows 10 or any windows software you may encounter a lot of drivers issues with Ryzen CPU's. By the time Ryzen Fixes their issues and work with Windows for new drivers and programs start using more cores would be already time to upgrade.
http://windowsreport.com/amd-ryzen-performance/
If you’re planning to buy an AMD Ryzen computer and run Windows 10 on it, think again. Recent reports confirm that AMD Ryzen’s performance is severely crippled on Windows 10, and there’s not much that you can do about it.
Ryzen is AMD’s first processor model to sport simultaneous multi-threading technology. According to AMD, Ryzen is 40% more efficient, consuming less power than its Intel counterpart. However, it seems that Windows 10 doesn’t really like it.
AMD Ryzen low performance on Windows 10
The Windows 10 scheduler is not able to correctly identify Ryzen’s principal core threads from virtual SMT threads. Actually, the OS believes that each CPU thread of a Ryzen processor is a real core with its own L2 and L3 cache.
As a result, Windows 10 doesn’t assign the tasks to a principal core thread. Instead, it schedules many of them to a virtual SMT thread, which of course, reduces the overall CPU performance.
There are many users who aren’t ready to give up on their AMD Ryzen-powered computer and hope that Microsoft and AMD will somehow fix this problem.
I just want MS/AMD to address the bug. I am not worried about how much it affects the improvement in games. We ought to be able to use the software and hardware we bought with hard-earned money properly in all fields, not just games. AMD/Microsoft please fix this asap
Microsoft has officially acknowledged this issue and confirmed is working on a fix. This means that the company will soon roll out a patch to address this compatibility issue. At the moment, Ryzen is not unusable, it’s just that it’s not as good as it could be. Let us hope that Microsoft sorts out the scheduler and cache issues as soon as possible.
You are talking about the AMD "hyperthreading" bug?
Well yes that was one of them, they actually have problems with different types of DDR4 Memory but eventually like I said is a new platform that needs to mature a bit more.
Ohh when I get ryzen that will be first thing i disable in BIOS, not worried about it at all
Getting high frequency ram with Ryzen is a waste of $ just normal DDR4 will do
High frequency has always been a waste, on visheras if you went over 1866 you had to match NB speeds and thats hit or miss if NB can do over 2000 on vishera, some cant even do 2200 or 2400, which really did not show much performance gains on vishera as compared to phenom2s with OCed NB, they flew with 2400 or higher.
I have always been able to hit higher RAM speeds using intel builds
Just to help educate a little.
Ryzen is compatible with all current DDR4 memory and officially supports upto 3600MHz.
However the sweet spot is 2400-2666MHz, this speed will work with all mainboards including cheaper options.
3000MHz and above will ONLY work at such frequencies in the flagship mainboards like ASUS CROSSHAIR for example and even then the maximum stable speed we achieve with a lot of messing around was 3200MHz, which really makes 3000MHz the maximum speed we advise.
Of course you could buy 3200 or even 3600 kit now, and just run it at a lower frequency with more aggressive CAS Timings and as BIOS updates come out then you might be able to achieve higher frequency.
As such we recommend 2400-3000MHz kits for use with Ryzen, faster kits will work just fine but you might have to run them below the rated speed and just set the memory timings more aggressive. :)
As I stated earlier, I only skimped through Ryzen in depth tech detail, but if ryzen NB holds same as visheras, it wont matter what mobo is if the CPU itself hinders NB speeds. Ill have to look into it if NB speed can stay put while RAM OCs higher
