Heya all.
I got fed up with these ridiculous prices in laptops, so I decided to build a semi-portable PC. Id like to build a nice small, portable, good value, but not too expensive little machine.
Mostly used for 1080p (opt1440p) Gaming (modern games like Fallout 4, Crysis, other Shooters, etc) Digital painting (Adobe Photoshop)
SO far this is what I put together:
http://pcpartpicker.com/user/Tibovation/saved/FMgMnQ
PCPartPicker part list: http://pcpartpicker.com/p/4WCZNG Price breakdown by merchant: http://pcpartpicker.com/p/4WCZNG/by_merchant/
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor ($200.99 @ SuperBiiz) CPU Cooler: Noctua NH-L12 37.8 CFM CPU Cooler ($60.89 @ OutletPC) Motherboard: ASRock Z97E-ITX/ac Mini ITX LGA1150 Motherboard ($114.99 @ SuperBiiz) Memory: Crucial Ballistix Tactical 16GB (2 x 8GB) DDR3-1600 Memory ($87.99 @ Amazon) Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive ($59.99 @ Amazon) Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card ($299.99 @ Micro Center) Power Supply: Silverstone Strider Gold 450W 80+ Gold Certified Fully-Modular SFX Power Supply ($75.65 @ SuperBiiz)
Total: $900.49
I am in Central Europe by the way, not US.
I am inexperienced in this! I researched for the last 3 days, a ton of hours. I would like to ask your advice.
Is there a way to make this cheaper with still having similar strength, better value?
Because I am almost at the price of laptops now, whic is the opposite of my goal.
I am trying to get down to $750-800 but I see that impossible so far, unless I can find second hand parts.
Will temperatures be fine with this build?
If I order these components, can I just build it, or do I need some extra components? (trays, cables, cooling paste, etc)
Will I be able to connect DP port display?
Is this motherboard good enough? Wifi is important to me, is this integrated good enough, or can I just plug in a wifi card, into this motherboard? Should I use another MB?
Since last years, I have very bad experiences so far with Gaming PCs in terms of smoothness, I owned an y510p 750m SLI laptop before, but that was a waste of money too, I sold it right away, even when I had good FPS(60+), everything was stuttering, and it just wasn't smooth for the eye (unenjoyable really, especially with shooters). Can I expect a build similar to this to be smooth?
Thanks a ton for the help guys!
Total: $900.49
