Components
Case - NZXT H440 Matte black/red
Motherboard - ASUS STRIX Z270E GAMING
CPU COOLER - H100I v2
i have a couple questions about setting up the fans and wiring
The case come with 4 fans 3 in the front and 1 rear, and then the h100i comes with two fans for a total of 6 fans. 3 intake 1 exhaust and then however i run the cooler. im going to mount the cooler on the top of the case.
[strike]
1. Should i run the fans in intake or exhaust?
2. should i have the fan on top (between case and rad) or bottom (between rad and mobo)?
3. the case has a fan controller on the back of it should i run all fans (including h100i fans to the controller?
4. where do i plug in the fan controller?
5. where do i plug in the pump for the cpu cooler?
6. will it work if i run all fans to controller? (i know it will work but would it be wise to?)[/strike]
UPDATE QUESTIONS/INFO (10/31/2017)
So im choosing to run all fans through the fan controller on the back of the h440.
Where do i connect the h100i v2 pump and corsair link cable?
Does it matter if i connect the h100i fans to the controller or should i connect them to the mb?
Motherboard Manual Link
i know my questions sound repetitive just want to make sure i get all the questions needed asked so i dont forget.
[strike]
