Building a computer: Help!!
gannet
Noobie alert!
I am currently building an Duron system using a gigabyte GA-7ZXE motherboard (VIA KT133A), Duron 1.1GHz and 1 stick of 256Mb 168DIMM PC133 CL3 memory.
I cannot get the system past the memory check. When booting the system hangs at the "Checking NVRAM.." message. The bus speed is currently set to 100MHz. I have replaced both the memory and processor, and tried different DIMM slots.
Please help, I have run out of ideas.
Solved it!
I unplugged all the IDE devices and this fixed the problem. It turns out the problem only occurs when th CD-ROM drive is connected. I suspect this is because it was pulled out of and old 486 machine :)
Gannet.
Can you tell me what operating system you're using? I'd be particularly interested to know if you have anything plugged into your USB ports while you're booting.
I'd rather have a full bottle in front of me than a full frontal lobotomy 😱
This may be something you've already checked and are aware about, but is the jumper set properly for the CD-rom? Is the IDE cable oriented the right way?
<font color=blue>
Guns kill people just like spoons make Rosie O'Donnell fat.
<font color=blue>
