Hello,
I want to build a PC for using programs as (3Ds Max, V-Ray, Revit, AutoCad, Rhinoceros and Grasshopper, Photoshop).
I'll be using Vray for 3D shots rendering and maybe animation video rendering in the future, but I'm confused on the built items:
CPU: I'm confused between Intel i7 4790k 4.0GHz quad core and i7 5930 3.5GHz 6-core. How can I compare a clock speed with number of cores to take the decision? what will affect rendering and using these programs?
I've heard about the overclocking, but it sounds unsafe. Also, is Xeon better?
GPU: Nvidia GeForce GTx 970 4GB.
Storage: SSD 120GB for system (samsung is good?). and WD HD 2 TB for storage.
Motherboard: I heard that x99 is the most suitable, but are there multiple types?
RAM: 32GB
Cooler: I concluded that the air cooler is better and safer than liquid cooling, is it right? if so, is Nactua NH-D15 CPU cooler is the best? does it cool just the CPU?!
Power Supply: XFS TS 650W +ATX power supply >>what about it?
Case: NZXT or cooler master?
last, I wanna know the definition of the term workstation and the difference between it and just PC?
Thanks in advance and I hope you can help me in this.
RAM: 32GB
