Dear Community,
I am planning to build a Power PC, which i will use for usual Home, Web and Multimedia use mostly, but also for Audio-Work and for Coding. I think investing in some more powerfull Parts will make the System last longer before beeing outdated.
So my build is as listed below. Please give me Feedback if some parts are not fitting together or are not worth the price or others might fit better.
Approximate Purchase Date: within the next month
Budget Range: open, but should be stay below 2200$ for the tower, the lower the better
System Usage from Most to Least Important: Surfing, watching Movies, Listening music, audio editing and DAW, recording audio, programming with different enviroments - statistics, data visualisation, maintaining data base, running VM
Are you buying a monitor: Yes
Preferred Website(s) for Parts: will look for cheapest in the net, but show here the links on newweg
Parts Preferences:not necesarilly, open for recomendations , thus i did research to choose what i chose and i like fans and PSU from be quiet!
Overclocking: Maybe
SLI or Crossfire: No
Your Monitor Resolution: 2.560 x 1.440, Acer ED323QURAbidp 31,5" curved
https://www.newegg.com/global/at-en/p/N82E16824011288?Description=Acer ED323QURAbidp&cm_re=Acer_ED323QURAbidp--24-011-288--Product
Additional Comments: I would like a quiet PC.
Case Fractal Design Define R6 USB-C - probably change the case Fans for be quiet ones ( Be Quiet BL067 )to have better software regulation for the cooling system
https://www.fractal-design.com/home/product/cases/define-series/define-r6-usb-c
PSU be quiet! Dark Power Pro 11 650W
https://www.newegg.com/global/at-en..._dark_power_pro_11-_-9SIA68V39G8952-_-Product
Mainboard Gigabyte Designare Z390 - i think thundebolt is good for the future?
https://www.newegg.com/global/at-en...igabyte_designare_z390-_-13-145-110-_-Product
CPU Intel Core i7 8700K - as i read its not worth paying more for the 9th generation, winning 2 more cores but loosing threads
https://www.newegg.com/global/at-en...re=intel_core_i7_8700k-_-19-117-827-_-Product
CPU Fan be quiet! Dark Rock Pro 4
https://www.newegg.com/global/at-en...et_dark_rock_pro_4-_-9SIA68V6YA3005-_-Product
RAM Corsair Vengeance 32GB DDR4, 2x16GB, 3200MHz
https://www.newegg.com/global/at-en...ngeance_32gb_ddr4_3200-_-20-236-541-_-Product
Graphics MSI Radeon RX 570 4GB
https://www.newegg.com/global/at-en...re=msi_rx570_armor_4gb-_-14-137-414-_-Product
SSD Samsung EVO 970 1TB
https://www.newegg.com/global/at-en...re=samsung_evo_970_1tb-_-20-147-743-_-Product
HDD WD Blue 6TB, 7200Rpm
https://www.newegg.com/global/at-en...estern_digital_blue_6t-_-22-235-009-_-Product
Drive Blu Ray, not really specified which, probably LG
also there will be some peripherals
Monitor as above
Keyboard probably Logitech CRAFT (should work with Linux)
Mouse Logitech MX 2S either Anywhere or Master
Sound Focusrite Scarlett 6i6 - i thpught for my usage now its fitting, if im getting serious i can go for higher priced and probably thunderbolt coupled ones
https://www.amazon.com/Focusrite-Sc...gateway&sprefix=focusrite+scar,aps,418&sr=8-4
Thanks in advance for your help
Overclocking: Maybe
Monitor as above
