To start with I am going to be piecing this system together over the next few months to correlate with Win 7 ship date but until then will run Win Xp.
I use Newegg.com for most of my buying of any parts for various reasons.
As for the requirements, I'm not looking for a HTPC on the cheap, what I'm looking for is to build a HTPC that will be a nice fit into the setup I have and will not only be for TV but also a current gaming rig. Noise is not a big deal as long as it doesn't sound like a jet engine.
The setup it is going to be coupled with is the following:
55" 120hz Vizio LCD TV max resolution 1920x1080 as monitor...I use computer from the couch which is 15 feet away.
Yamaha YSP-4000 soundbar HDMI capable, got a great deal on it on craigslist.
Logitech DiNovo Edge keyboard.
Logitech MX 1100 mouse.
Onkyo reciever TX-SR706 HDMI capable.
Now with that said I plan on going with: (current prices listed)
AMD Phenom II X4 945 Deneb 3.0GHz Socket AM3 125W Quad-Core ($225)
ASUS M4A79T Deluxe AM3 DDR3 AMD 790FX ATX AMD Motherboard ($199)
CPU cooler is yet TBD (~$100?)
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s Internal Hard Drives ($99)
Hauppauge WinTV-HVR-2250 Dual TV Tuner / Encoder 1229 PCI-Express x1 ($129)
Logitech Harmony 1100 Universal Infrared Remote Control ($439) not only control PC, TV, Stereo, lighting in room and also thermostat the last 2 are already working
***OCZ Reaper HPC Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) ***in current system
***OCZ Fatal1ty OCZ700FTY 700W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply***in current system
***XFX PVT80GGHE4 GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card***in current system but will be upgraded at some future time maybe 8-12 months from now
So now with that set up can anyone suggest a HTPC case that will fit the video card especially? Anyone with hands on experience with the case they are suggesting would be of great help.
Obviously cooling is a necessity but as i said previously low or no noise is not required because the current system I have is pretty loud but with the soundbar it cancels that out pretty well. Besides this whole setup is on the wall to the side of the TV with the reciever and for some reason the noise level is dampened due to room acoustics and distance from couch to this setup.
Any thoughts and/or suggestions? You have my thanks in advance.
Thermaltake Black Aluminum / SECC Steel DH102 VH2001BNS ATX Media Center / HTPC Case ($519)
Moneual LAB Black Aluminum 972B ATX Media Center / HTPC Case ($549)
SILVERSTONE Silver Aluminum CW03S-MT ATX Media Center / HTPC Case ($649)
These were the 3 I have been looking at the latter being a tad pricey.
