Question building my first pc and want some advice/help
Apr 27, 2024
8
i have a budget of 1200 pounds (uk) and saw a bunch of reveiws online with the components of the build but idk how it will work together so i hope u guys can help me
pc build - link
Your build looks reasonable.
FWIW:
MY build process:
Before anything, while waiting for your parts to be delivered, download
and read, cover to cover your case and motherboard manual.
Buy a long #2 magnetic tip philips screwdriver.
A small led flashlight is also useful.
I find it handy to buy a power switch like this for testing.
https://www.newegg.com/p/N82E168121..._switch-_-12-119-009-_-Product&quicklink=true
1. I assemble the critical parts outside of the case.
That lets me test them for functionality easily.
A wood table or cardboard is fine.
2. Plug in only the necessary parts at first. Ram, cpu, cooler, psu.
Do not force anything. Parts fit only one way.
Attach a monitor to the integrated motherboard adapter if you have one, otherwise to the graphics card.
3. If your motherboard does not have a PWR button, momentarily touch the two pwr front panel pins with a flat blade screwdriver.
4. Repeatedly hit F2 or DEL, and that should get you into the bios display.
5. Boot from a cd or usb stick with memtest86 on it. memtest will exercise your ram and cpu functionality.
They boot from a usb stick and do not use windows.
You can download them here:
If you can run a full pass with NO errors, your ram should be ok.
Running several more passes will sometimes uncover an issue, but it takes more time.
Probably not worth it unless you really suspect a ram issue.
Opinions vary on updating the bios.
Normally, one does not update a bios unless there is a fix for something that is impacting you. I violate this rule on a new build and will update to currency up front.
Use the usb option, not the windows option.
If there is a severe problem, the impact is small.
6. Install windows.
7. Install the motherboard cd drivers. Particularly the lan drivers so you can access the internet.
Do not select the easy install option, or you will get a bunch of utilities and trialware that you don't want. Drivers only.
7. Connect to the internet and install an antivirus program. Microsoft defender is free, easy, and unobtrusive.
8. Install your graphics card and driver if you tested with integrated graphics.
You will need to remove the graphics card later to install your motherboard in the case.
As a tip when screwing the motherboard into the posts, give the screw a small counterclockwise turn until you feel a click.
That lets you know that the screw will engage properly.
Make a note of how the graphics card latches into the pcie slot.
The mechanism will be hidden under the card and may be difficult to work if you have not previously checked how.
9. Update windows to currency.
10. Only now do I take apart what I need to and install it in the case.
11. Now is the time to reinstall your graphics card.
FWIW:
MY build process:
https://www.newegg.com/p/N82E16812119009?Description=power switch&cm_re=power_switch-_-12-119-009-_-Product&quicklink=true
6. Install windows.
ty for the tips its a huge help
pc build - link
Your choice of RAM is a obvious bottleneck. You want DDR5-6000 CL30 for these AM5 builds. Try this.
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor (£177.99 @ AWD-IT)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler (£35.00 @ Computer Orbit)
Motherboard: ASRock B650M PG Lightning Wifi Micro ATX AM5 Motherboard (£123.13 @ Amazon UK)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (£108.36 @ Amazon UK)
Storage: *Lexar NM710 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£70.99 @ CCL Computers)
Video Card: XFX Speedster QICK 319 Core Radeon RX 7800 XT 16 GB Video Card (£459.98 @ Scan.co.uk)
Case: *Montech AIR 903 BASE ATX Mid Tower Case (£54.98 @ Scan.co.uk)
Power Supply: *SeaSonic FOCUS GX 750 W 80+ Gold Certified Fully Modular ATX Power Supply (£83.98 @ MoreCoCo)
Total: £1114.41
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-05-02 09:22 BST+0100
