[SOLVED] Building new PC ...help me out
Oct 31, 2019
Hello there, I'm building new pc for a first time
Here is list of components help me its compatible or not
processor -
Intel Core i7 9700K Desktop 9th Generation Processor 8 Cores up to 4.9 GHz Turbo Unlocked LGA1151 300 Series 95W
Water Cooling-
CORSAIR Hydro Series H100i PRO RGB AIO Liquid CPU Cooler, 240mm, Dual ML120 PWM Fans
Motherboard-
ASUS ROG Strix B365-G Gaming mATX Gaming Motherboard for Intel 8th and 9th Gen CPUs (300 Series 1155 Socket)
Ram-
G.Skill Trident Z RGB Series DDR4 Memory Module for AMD Ryzen and Threadripper 8GB X 2pcs 3200Mhz
Video Card-
GALAX GeForce® RTX 2060 Super (1-Click OC) 8GB GDDR6 256-bit DP/HDMI/DVI-D Graphic Card
Case-
Antec DF500 RGB Mid Tower Gaming Cabinet Support ATX, M-ATX, ITX Motherboard with Tempered Glass Side Panel, 3 x 120mm RGB Fan Front Preinstalled (0-761345-80003-7)
SMPS-
Corsair VS550 550W Active PFC 80 Plus Power Supply (Black)
Is it compatible or there is something plz help me out
This should be better...
PCPartPicker Part List
Type|Item|Price
CPU | AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor | ₹29804.00 @ Newegg India
Motherboard | MSI X570-A PRO ATX AM4 Motherboard | ₹14894.00 @ Newegg India
Memory | ADATA XPG SPECTRIX D41 16 GB (2 x 8 GB) DDR4-3600 Memory | ₹11147.00 @ Amazon India
Storage | Kingston A1000 480 GB M.2-2280 NVME Solid State Drive | ₹4395.00 @ Amazon India
Storage | Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive | ₹2899.00 @ Amazon India
Video Card | XFX Radeon RX 5700 XT 8 GB THICC II Video Card | ₹36244.00 @ Newegg India
Case | Corsair SPEC-01 RED...
compatible? yes
suggested? no not without a change on that PSU, that is literally the cheapest PSU corsair sells, every sense of the word CHEAP.
the PSU will feed AND protect the new parts do not go cheap on the PSU.
a 9700k will need more juice when overclocked and the VS550 is not suggested for ANY overclocking at all.
seasonic focus plus
EVGA g2/g3 series
corsair RMx or the TX series
you also have no storage so I suggest an SSD or a HDD.
Reactions: Phaaze88
not sure I understand the question. the mATX board is a good one, Asus has been trusted by me for 20 years.
ATM? you mean ATX the larger motherboard form factor? if you need the extra expansion a full sized board provides then mATX is a bit small. for most people mATX is fine unless you are planning to fill those slots then get what you need now.
for your consideration
CPU: Intel Core i7-9700F 3 GHz 8-Core Processor ($329.86 @ Amazon)
CPU Cooler: Noctua NH-U12S 55 CFM CPU Cooler ($59.95 @ Amazon)
Motherboard: ASRock B365M Pro4 Micro ATX LGA1151 Motherboard ($74.89 @ OutletPC)
Memory: Team T-Force Delta RGB 16 GB (2 x 8 GB) DDR4-3200 Memory ($69.98 @ Amazon)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($97.99 @ Newegg)
Video Card: Gigabyte GeForce RTX 2060 6 GB GAMING OC PRO Video Card ($319.99 @ Amazon)
Case: Antec GX500 ATX Mid Tower Case ($67.09 @ Amazon)
Power Supply: SeaSonic FOCUS Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply ($69.90 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($99.89 @ OutletPC)
Monitor: LG 24GL600F-B 23.6" 1920x1080 144 Hz Monitor ($149.00 @ Amazon)
Total: $1487.54
Generated by PCPartPicker 2019-11-01 00:22 EDT-0400
keyboard and mouse are very personal and for you to choose.
Even RAM isn't available in my country....can I go for G.Skill Trident Z RGB Series DDR4 Memory Module for AMD Ryzen and Threadripper 8GB X 2pcs 3200Mhz???
In my country I have to pay 2250$ for all of these items. 🙁
Type|Item|Price
Case | Corsair SPEC-01 RED ATX Mid Tower Case | ₹2980.00 @ Amazon India
Power Supply | Corsair Vengeance 650 W 80+ Silver Certified Semi-modular ATX Power Supply | ₹7999.00 @ Amazon India
| Prices include shipping, taxes, rebates, and discounts |
| Total | ₹110362.00
| Generated by PCPartPicker 2019-11-01 11:56 IST+0530 |
