My specs: https://pcpartpicker.com/list/6b7fcT
I built the pc and everything lights up; the gpu, motherboard, ram, and cooler, just fine. However, it doesn't display anything on the monitor. When I plug the cable in ((I have tried HDMI and display port cables) nothing displays on the screen. If the cable is plugged into the monitor when I plug the other side into the pc the monitor will light up but will then say "no signal entering power-saving mode.." (It says this anytime I turn the monitor on when everything is plugged in also). I've messed with the RAM and the gpu, the only other option I haven't done is fully take everything apart because I haven't had the time.
I've tried doing a bunch of different things but I'm hoping someone might have an explanation for what could be wrong before I take it all the way apart.
