Question Burnt motherboard. Is it possible to fix?
Jun 27, 2019
I have a Hasee laptop which uses the clevo model P655-HP6. It shutdown when I was normally using.
I cannot boot it up right now and I think the problem is with this burnt part that is on the second image.
I wanted to know what is the part that is burnt. Is it a mosfet? And whether this could be fixed without replacing the whole motherboard.
Thanks for the help!
It looks like part of the power delivery circuit for the GPU you zoomed into, next to it, to the right. The repair wont be long lived and if anything I think the issue is also with the quality of the component used. You're better off replacing the board.
The main reason I am asking is that if the motherboard needs to be replaced I will need to send it to the manufacturer in China and that will cost a lot on deliveries. Is the power delivery circuit hard to find or costly? Is it possible to be fixed at a computer repair shop?
Thanks for the reply!
