Buying graphic card, need help to choose
best graphic for me
  • Sapphire 7850 1GB/DDR5,/DVI/HDMI/256bit/11200-16-20G
    Votes: 0 0.0%
  • MSI GTX650-Ti Boost 2GB, DDR5/HDMI/DVI/192bit/N650Ti-2GD5/OC BE
    Votes: 3 100.0%
  • MSI 7850 OC 1GB/DDR5,/DVI/HDMI/DP/256bit/R7850-1GD5/OC
    Votes: 0 0.0%
  • Total voters
dartxxq
My configuration is
AMD fx 8320
2x4 gb 1600MHz ddr3 ram
asus M5A97 R2.0
chieftec 600w
benq 21.5 full hd monitor 1920x1080
Problem is next:
My old radeon 6790 graphic is dead and i must to buy new
In my region i must to choose from
My question is next, radeon graphic card are 256bit, and gtx650ti is 192bit,
but gti is 2gb and radeon cards are 1gb, what is my best choise, i want to play new and incoming games and my budget is limited to this card, can not go any higher with price
I thank in advance for answers
100% on the GTX, ive always preferd nvidia, and between those, the 2gb is a very good improvment, i have the exact same board, fx8350 and the GTX and i preety much max out everything on a 1680x1050.
Its the best i can recommend 😀
The 256-bit makes a difference if you run dual or triple monitor setup; see it as lanes on a highway. The more lanes you've got, the more data can pass through, but still at limited speed. Go with more memory; better and larger textures.
