I'm currently building a PC for the first time in 7 years and I'm curious if there is any risk with a few different wires and the AIO tubing for my CPU cooler, for the way I have it set up currently.
Please see the attached image:
1. Will the tubing be okay in this arrangement? Will having it right next to the CPU power connector cause any heat issues? Will it be a problem for airflow?
2. Will this tubing arrangement cause any problems with leaks? There doesn't seem to be much tension, but it is slightly more than if I had it going straight down and across the middle of the board.
3. Will the USB Corsair Link cable be okay running directly next to the CPU 8 pin power? Is it okay to route this USB cable underneath the motherboard heatsync?
Thank you for your time in reading my questions!
