Cable for 3440 X 1440 and 60hz+
PCguy132
Commendable
Apr 5, 2016
62
I have found a monitor with 3440 x 1440 and 100 hz. It has DisplayPort 1.2 and HDMI 1.4. The problem is that i cant find a cable that supports over 60 hz at that resolution. That means that the monitors last 40 hz is just nothing. I cant find a way to get it over 60 hz. But who makes a monitor with 100 hz. And only 60 is useabel?
What is the name of the panel? It might be a 60Hz panel, but overclockable to 100Hz because current 4k panels don't go over 60.
Its this one:
https://www.asus.com/dk/ROG-Republic-Of-Gamers/ROG-SWIFT-PG348Q/
A shift on the side makes it overclocking to 100 hz. But why making that switch If it isnt possible to use it anyway?
(Im sorry that i "downvoted" your post. It was a mistake :/
