mundus1111 Dec 5, 2020 3 0 10 Dec 9, 2020 #1 My 4+4 CPU cable won’t reach because my GPU is blocking it. Can I put it over like this? https://imgur.com/a/vYadj8H View: https://imgur.com/a/vYadj8H
Solution RealBeast Dec 9, 2020 Sure, that is a common issue and as long as the cable doesn't hit the fan blades you are fine.
RealBeast Titan Moderator Sep 13, 2010 17,109 474 104,790 Dec 9, 2020 Solution #2 Sure, that is a common issue and as long as the cable doesn't hit the fan blades you are fine. Upvote 0 Downvote Solution
S sizzling Titan Oct 18, 2006 27,231 3,301 112,240 Dec 9, 2020 #3 Cant it run up the back side of the panel the motherboard is mounted too? Reactions: GabrielV Upvote 0 Downvote
