T torini Jan 13, 2019 3 0 10 Mar 2, 2019 #1 So I have a li-po battery which says 15Wh on it, I'd like to calculate the capacity in mAh, but which voltage do I use, nominal (3.7V) or full charge voltage (4.2v) ?
Solution S S sizzling Mar 2, 2019 Nominal voltage. Remember the rated capacity is higher than what you can safely use.
S sizzling Titan Oct 18, 2006 27,218 3,268 112,240 Mar 2, 2019 Solution #2 Nominal voltage. Remember the rated capacity is higher than what you can safely use. Upvote 1 Downvote Solution
