I a general question about calculating the power UPS needed for different setups.
A typical spec for a UPS (just an example) could be 3000VA / 2250W. Does the total amount of computer power supplies wattage, when added up, have to equal less than the 2250W? Is the 3000VA simply the amount of time the UPS can power 2250W for? If you add extra battery packs then that would only increase the VA value and extend the run time?
