Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have a Leica Camera connected via USB to an XP Pro/SP2 system. It has
worked since plugged in. Never needed to install a driver. It has
always prompted with the AutoPlay. Selecting "Copy pictures to a
folder on my computer using Microsoft Scanner and Camera Wizard" has
always worked in the past.
It has stopped working and I cannot figure out why.
This is not an AutoPlay issue. It is a WIAACMGR.EXE, I would guess.
Heres the current status.
I have two "Scanner/Camera" devices. One is clearly WIA compliant. An
HP ScanJet 4670 and the Leica Digilux I.
The ScanJet shows up in the Control Panel applet "Scanners and
Cameras." The Leica does Not.
When the Leica Digilux AutoPlay prompt listing various Events to
choose, the "copy pictures" does display. Selecting it: NOTHING
HAPPENS. No error message, nothing. WIAACMGR.EXE, however, is listed
in the Task Manager list.
If I explore the Leica and click on PictureTasks.GetPictures ... The
Scanner and Camera Wizard loads: I get the "reading picture
information" dialog, the scanner lamp turns on, and up comes the
picture and scanner wizard reading to use the scanner.
If I try and load manually using:
C:\WINNT\system32\wiaacmgr.exe -SelectDevice
same thing. The wizard loads for the "hp scanjet 4600 series" -- and
no longer sees the camera AT ALL.
I've confirmed registry settings for the device and for AutoPlay. I
found a page on MSDN:
http://tinyurl.com/4dntd
With instructions for "Assigning a Device Handler to a Device"
So I tried setting
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Enum
USB
<my Vid_Deivce>
<my pid>
Device Parameters
DeviceHandlers [REG_SZ]= MSWiaEventHandler
No help.
Any ideas how to recover the ability to use the Camera and Scanner
wizard with the camera?
Since the scanner also has a non WIA twain driver -- and other
interfaces with which I can get a scan -- I'd be happy to remove it's
WIA ability if that meant I could get back the Camera part...
Thanks in advance for any ideas.
Falstaff
Falstaff's Profile: http://extremetechsupport.com/forum/member.phtml?userid=563
View this thread: http://extremetechsupport.com/forum/showthread.phtml?t=102674
So I tried setting
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Enum
USB
<my Vid_Deivce>
<my pid>
Device Parameters
No help.
Falstaff
