Camera and Scanner Does not Load for Camera
Falstaff
5
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
testHi Edward.
Oh, yes, the camera is being seen by the computer. If I select
anything else on the autoplay list, it executes and functions as
expected (Print, Picassa, Explore, etc etc). It is only the Camera and
Scanner Wizard that does not display.
I've tried plugging into other available USB ports, the generate a new
registry entry when the "new" hardware is discovered. No help.
I do get a sound when attached.
Edward W. Thompson Wrote:
> I aplogize if this is overly simplistic but have you satisfied yourself
> that
> the machine and camera are at least 'talking' to each other by that I
> mean
> is the cable OK? As I am sure you know when you plug the USB cable
> into the
> machine with the camera 'on' you should get a sound indication a
> connection
> is made. If the device (camera) is recognized when you plug it in, does
> it
> show in Device Manager either as the camera or as an 'unknown device'?
Falstaff
Falstaff's Profile: http://extremetechsupport.com/forum/member.phtml?userid=563
View this thread: http://extremetechsupport.com/forum/showthread.phtml?t=102674
I had same problem with my camera not opening up the wizard when plugged in.
I got the sound and an icon showing I had plugged in, but it just showed as a
USB mass storage device. I was told that "real Player" causes the problem.
I removed real player and my camera works like it should. I plug it in to
USB and XP opens up the camera wizard asking me what to do with photos.
"Falstaff" wrote:
> testHi Edward.
> > that
> > mean
> > into the
> > connection
> > it
> Falstaff
