[SOLVED] Can a Commander Pro power and control RGB?
Mar 25, 2020
Hi,
I am about to build another PC and Im going to get some ll120s. I was wondering if the Corsair Commander Pro can both power and control rgb and fan speeds for 6 individual ll120s ?
Thanks!
Individually? No. You would need the Corsair LED Fan Hub, which usually comes with 3-packs of fans. If one didn't come with yours, you can buy it for only like $10 directly from their site.
The LED cables plug into the Fan Hub, and the Fan Hub plugs into one of the two Commander Pro's LED ports. It's powered by a SATA connection, just like the Commander Pro. The fan control cables are what plug directly into the Commander Pro. Make sure you have an open USB 2.0 header on your motherboard, as that is where the Commander Pro will connect in order to control everything through the iCue software.
