Nothing is ruled out, until proven working.Hello, thanks for your answer, its not the PSU because i replaced it and it still happens the shutdowns critical erros (Kernel Power 41 (63) ).
Already did reset windows 2 times, nothing solves.There isn't a chance... Reset windows and see what happens
"reset" is the wrong term.Already did reset windows 2 times, nothing solves.
Already did turn off the fast startup, changed power options.
Replaced PSU
Replaced RAM
Nothing solves the issue 🙁
Yes, a full format and reinstall."Wipe and reinstall" are you talking about a full format?
No i didnt i dont have another one.
Like i said ive been getting this issue with random restarts when gaming displaying colorful lines (not BSOD)Yes, a full format and reinstall.
"reset" is NOT the same thing.
How To - Windows 10 clean install tutorial
If you are looking for the Windows 11 Clean install tutorial, you can find that here: Windows 11 Clean install tutorial (Click here) Otherwise, welcome to the Windows 10 Clean install tutorial This tutorial is intended to help you, step by step, to perform a clean install of Windows...forums.tomshardware.com
You issue may be a dying GPU.
Or is might be something else.
Very hard to diagnose without some working part to swap in.
What i actually think it was, my previous PSU was a cheap 500W i had it for quite a while and it might damaged the GPU itself.Ya I was about to say the gpu could not be taking the power correctly.
And what, specifically, will this heatgun do?Well thats yorr problem... If it doesnt work with a new psu then heatgun it
