Question Can anyone help me with spacing?
I'm confused; you say you want an Intel 13600KF which doesn't have any graphics so you're also getting an Intel Arc A750. But if you got a standard 13600K not F it would include Intel UHD Graphics 770 which is higher than the Arc A750. I'm not sure this would provide better performance.
I think I added the wrong CPU, the CPU should not have graphics, Again I'm new to this so a lot of this is very new to me, Any help would be great appreciated
Okay, so I don't want integrated graphics because that would use some of the resources from the CPU, and a lot of the games that I play are very heavy, so that would cause some issue with that
It wouldn't take any more resources from CPU than dedicated GPU. only some RAM but neither of those graphics would make heavy gaming good. You will need much better one.
