[SOLVED] Can anyone help tell me if my current parts picker build is solid machine for rendering
That powersupply is meh for that high end a system.
I suggest something like the Rm750i.
otherwise, yeah.
You can save a buck on the motherboard, and do you really need that much, and RGB on top of that memory?
Also, what cooler will you use?
otherwise, yeah.
