Yes, you can use fan spliter cable or a hub. https://www.amazon.com/Splitter-Computer-Extension-Converter-TeamProfitcom/dp/B07F8LV1BYi have 2 case fans to plug in but i dont have another cha_fan so i was wondering if the other options would be compatible or would cause any problems.
Oh yeah I missed that one. But would the m.2 fan work as I have 5 fans and only 4 cha_fansAccording to https://www.asus.com/Motherboards/ROG-STRIX-Z490-A-GAMING/specifications/ it has 2 x Chassis Fan connector(s)
It should work just as well but I don't know if speed is adjusted by M.2 temperature or could be remapped to another sensor, should be able to see it in BIOS.Oh yeah I missed that one. But would the m.2 fan work as I have 5 fans and only 4 cha_fans
ok thank you very much kind sir. P.S first time building a computer.It should work just as well but I don't know if speed is adjusted by M.2 temperature or could be remapped to another sensor, should be able to see it in BIOS.
You are welcome, "There's always first time" is what I said to my girlfriends but that goes for computer building toook thank you very much kind sir. P.S first time building a computer.
