[SOLVED] Can CPU cooler melt hot glue?
Feb 23, 2021
7
I have an old Macbook pro 13 inch (mid 2014) and it was having cooling issues.
I took out the back panel and found that the rubber which is present between the fan and the heatsink is missing. So i put hot glue there as i thought it would help stabilize the temperatures. Now im worried that the hot glue might melt. Is it possible or should i not worry.
The rubber would be for quieting the fan I would think....
Are you able to take a couple of photographs and post here via imgur?
Hot glue melting temperatures:
https://askinglot.com/how-hot-does-a-glue-gun-get
https://www.bobvila.com/articles/be...aching temperatures of,, wood, and even metal.
Melting seems unlikely and if melting occurs the Macbook is likely to be permanently damaged by some really high temperature event.
However, I would be concerned about any heat transfer requirements.
Just my immediate thoughts.
