I recommend you do NOT do that.
A mobo has at least two different fan automatic control systems. One is specifically for the CPU chip and it is guided by a temperature sensor built into the CPU. Then there's another (sometimes more than one) for case ventilation fans, and those are guided by a different sensor on the motherboard. You always want the CPU chip cooling guided by the CPU chip internal sensor using the CPU_FAN header.
Beyond that, every fan header has an important additional function. It monitors the fan's speed signal for FAILURE and sends you a warning message if a fan fails (shows zero speed). But on most mobos the way this is done for the CPU particularly is more intense, and this ONLY happens on the CPU_FAN header. On...
