Question Can i install Pci 4.0 card on PCI 5.0 x16 using Ryzen 5 8400f
Feb 11, 2025
29
I have Motherboard Asus Tuf Gaming B850m-plus wifi
I have RTX4060 ti 8gb , NVME Kingston 1 tb and Ryzen 5 8400f
So can i plug the GPU on Pci 5.0 x16 port and pul the NVME on Pci 4.0 ( NOTE that the CPU ryzen 5 8400f has only 16 pci lanes availiable
SO will be any compitability issue problems ??
yes but my motherboard has 2 Pci x16 slots ( one pci 4.0 x16 and one pci 5.0 x16 ) so can i put gpu on pci 5.0 x16 as it has easy latch features
No.
Your motherboard has single PCIE x16 slot
(operates in PCIE 5.0 mode with 7000 or 9000 series cpu or in PCIE 4.0 mode with 8000 series cpu).
and single PCIE 4.0 x1 slot.
There are no two PCIE x16 slots on your motherboard.
With Ryzen 5 8400f all PCIE slots and all M.2 slots operate in max PCIE 4.0 mode.
PCIE 5.0 mode is not available for your hardware.
Note PCIE x16 slot will operate in x8/x4 mode (x16 mode is not available).
But your graphics card uses x8 connection, so this limitation doesn't impact anything.
so can i put GPU at pci 5.0 x16 slot or better put it on pci 4.0 x16 slot ?
With Ryzen 5 8400f you don't have a PCIE 5.0 slot.
All slots operate in PCIE 4.0 mode.
And your motherboard has single PCIE x16 slot.
No.
