Question Can i run this build with be quiet System Power 9 400 W 80+ Bronze Certified ATX Power Supply .i dont think my gpu can go higher than 130 watts
Jan 2, 2024
8
AMD Ryzen 5 5600G 3.9 GHz 6-Core
Processor
MSI A320M-A PRO MAX Micro ATX
AM4 Motherboard
G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory
Western Digital Caviar Blue 250 GB3.5" 7200 RPM Internal Hard Drive
Samsung 970 Evo Plus 250 GB M.2-
2280 PCle 3.0 X4 NVME Solid State
Drive
PowerColor Fighter Radeon RX 6600
8 GB Video Card
And really, it's an old group-regulated PSU too, so you're down to 384W of +12V power at most, which is *much* less than ideal than a 400W PSU with a modern topology.
It's time to replace the PSU if you want to use the GPU.
I dont have enough money to buy rx 6600 and a new spu rn should i wait till i have enough money for both or should i buy a lower watt gpu
Processor
AM4 Motherboard
be quiet System Power 9 400 W 80+ Bronze Certified ATX Power Supply​
Processor
AM4 Motherboard
Drive
8 GB Video Card
The power supply is the heart of the PC. It should be the first thing you upgrade. Putting the cart before the horse is what you are trying to do. Doesn't work that way. You need more PC building and trouble shooting experience.
