[SOLVED] Can I upgrade my cpu on Toshiba Satellite pro C50-A-1EU?
Hi, is it possible to upgrade my cpu (Intel core i3 3110M 2.40GHz) with a more powerful one?
Seems to be possible. CPU is socketed on this laptop.
Note - if you decide to change cpu, then you can put only same or lower tdp cpu in there. Or else laptop cooling system will not be able to handle it and your laptop will overheat.
i3 3110M is 35W cpu.
Only models, that would make sense to upgrade to are:
i7-3612QM (PGA988 variant),​
i7-3632QM (PGA988 variant).​
Rest of them are either higher tdp models or simply not worth it to upgrade from i3 3110M.
It's a notebook, correct?
Generally, mobile CPUs are soldered onto their motherboards and cannot be easily upgraded/replaced. So probably not.
You'll have to look at the service manual of your board to see if the chip is socketed or soldered.
Reactions: Polyslife
If I upgrade my RAM and I buy a SSD disk on this pc, how much does the PC performance increase? I usually play minceraft on my laptop , and even if it's playable, it's not so fluid, and I'm a casual gamer so I don't really need a powerful pc, any suggest?
Try this on youtube :
Toshiba Satellite C50 cpu upgrade
View: https://www.youtube.com/watch?v=jr3xytU_zu8
Seems to be quite an easy change if you've done 1 or 2 before , but even first time change would be easy if taken at a sensible pace , no special tools needed , screw driver , cpu and new paste.
i3 to i5 /i7 would greatly improve gaming , but an SSD is a good second choice for extra boost ,
you don't mention how much or what RAM you have.
Reactions: Rype69
Now I Have 6GB of RAM (don't know what type). I've being doing some research on internet, the maximum RAM that this PC can handle it's 16GB (if i'm not wrong :)
TBH with 6GB RAM that should be plenty for games etc , I would go for CPU first or SSD second or both if you feel rich :)
Plus when changing CPU it will allow you to clean out dust and debris from heat exchanger ( radiator ) that you normally can't get to , remember the hotter Laptop runs the more the CPU will throttle its power to keep itself safe , so a hot running lappy will naturally run slower and slower.
CPU s/h on eBay probably £50 , SSD 500GB to 1000GB ( 1TB ) new about £100/150 , s/h SSD's are fine if you know it hasn't been used hard for writes ( like from a data centre or server farm ) most sellers of s/h SSD's will list info on the health of drive which will tell you how much use its had , s/h CPU's are fine ( these can only be damaged if majorly over clocked but the sort of CPU you are looking at I very much doubt anyone would take the trouble to squeeze that little bit of power gain that can be extracted from that model of CPU by over clocking )
Changing CPU , 1/2 hr work to physically change , windows should simply load any new drivers on boot .
SSD you would need to image the original drive onto SSD or load windows fresh , both take a couple of hours to do.
