hi, next year i want to build my first pc and im still confused can i use 2 m.2 on my motherboard : b550m pro vdh wifi. my question is, can i use first slot for m.2 nvme and second slot for m.2 sata because i dont want lot of cables usage on my pc
so i should put my nvme at the second slots ? can it slow the performance of my nvmehttps://www.msi.com/Motherboard/B550M-PRO-VDH-WIFI/Specification
2x M.2 slots (Key M)
M2_1 slot (from AMD Processor)
Supports PCIe 4.0/ 3.0 x4 1
Supports SATA 6Gb/s
Supports 2242/ 2260/ 2280 storage devices
M2_2 slot (from AMD B550 chipset)
Supports PCIe 3.0x4
possible. but only the faster m2 slot work with sata type
so it's will just fine ?that wd blue is gen 3. so it will not be slower on the chipset m.2
